Technical Front Shock Angle on a Duece
Discussion in 'Traditional Hot Rods' started by qmdv, Aug 9, 2019.
  1. I bought lower shock mounts that bolt to the bottom of spring perch. As you can see the angle is off as the shocks will rub on spring bolts
    Here is the lower mount. It is the stainless variety and I think I can heat them up and bend them as desired
    What say you guys that have experienced this
  2. 37gas
    37gas
    Turn the shackle around , put a spacer on the top shock and bottom shock eye. A little here a little there should make it work
    da34guy and 3340 like this.
  3. Do you have the shock on the front? it's hard to tell in the photo, the nuts on the shackel should be facing the rear of the car. HRP
    1946caddy, OLSKOOL57 and 3340 like this.
  4. Mechman_22
    Mechman_22
    from Nc
    Flip the shackle so the nut is on the other side
    spiffy1937 and da34guy like this.
  5. Yes shocks oat front of axle. Yes the nuts at back will help. I am trying to use F-1 shock mounts for the top mount
  6. 6sally6
    6sally6
    Sorry but...........Stainless(especially that thick) don't."heat & bend". Mild steel...yes....Alum...no
    6sally6
    3340 likes this.
  7. I still think that the top of the shock is a bit too far back. Tweeking that lower mount a bit would really help.
  8. How about tweeking the upper mount?
    Phil
    da34guy likes this.
  9. Will tweek in the morning and report back
