Technical From single to dual exhaust (oldsmobile)
Discussion in 'The Hokey Ass Message Board' started by oldsfrench, Sep 24, 2020.
  1. oldsfrench
    oldsfrench
    from France
    Hello hambers
    I have 2 98 oldsmobile 4door
    1956 and 1953
    They both are single exhaust
    I thought to put dual exhaust on them with mufflers for a good loud sound
    Can someone show pictures ?
  2. On the 56, the exhaust runs from the drivers side around the front of the motor to a flow through on the passenger side manifold. You can either make a block off plate for the front half of the passenger side manifold, or find a second drivers side manifold to mount on the passenger side. In that case, you'll have to switch the head studs to bolts and fab up a new generator mount bracket that picks up off bolt mounting points.
    dana barlow likes this.
  3. jimmy six
    jimmy six
    Take it to a muffler shop and tell them what you want.
  4. Rckt98
    Rckt98
    I would have thought the 56 98 should have factory twin exhausts? My 98 coupe certainly did and yes the front of the right side manifold had a blanking plate.
  5. Not stock.
  6. Rckt98
    Rckt98
    I thought the 98's were twin and the 88's single? I'm probably wrong though.
  7. engine138
    engine138
    from Commack NY
    Im running fenton headers so they dump out in back of engine stock manifolds run to the front of engine
  8. I have two 324's that were pulled out of 98's (a 54 and a 55). Both had the exhaust wrap around the front of the engine to the passenger side.
    Possible that they changed to dual exhaust in 56 or later, but not sure.
  9. triumph 1
    triumph 1
    My original’56 324 olds had a factory pipe going under the front of the oil pan
    connecting the manifolds & exiting one manifold in one pipe.
  10. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Take Jimmy's advise and save yourself a lot of cussing, skinned knuckles and rust in your eyes! Take it to a known good muffler shop, tell them what you want, go to the local watering hole until its done. ;)
  11. Rckt98
    Rckt98
    Yes, but did it come out of a 98 or 88?
  12. oldsfrench
    oldsfrench
    from France
    thanks guys for your answers ,
    muffler shop are not really easy to find here in france .....
    i'll try to do the best i can .....
