Art & Inspiration <<<< Friday Art Show 1/29/2021 >>>>
Discussion in 'The Hokey Ass Message Board' started by 57 Corvette ~ Bob, Jan 28, 2021.
  1. 57 Corvette ~ Bob
    57 Corvette ~ Bob
  2. 41 GMC K-18
    41 GMC K-18
  3. mark schanfeldt
    mark schanfeldt
  4. quick85
    quick85
  5. Lil32
    Lil32
    my wife has an entry for today
  6. Lil32
    Lil32
  7. Lil32
    Lil32
    Yard Art Redcrest OR
  8. DDDenny
    I see this when I drive to the Oregon Coast
    Not my photos.
  9. DDDenny
    This guy must really like Studebakers!
    John B, ME.GASSER, b-bop and 27 others like this.
  10. Good morning. A little yard art I did a few years ago. 20160113_140637.jpg
  11. DDDenny
  12. Stogy
    Stogy
  13. battersea boys
    battersea boys
    from surrey
  14. battersea boys
    battersea boys
    from surrey
  15. robber
    robber
    from Colorado
  16. It's Friday and I love it. Thanks to all of you that share your work.
    Later,
    Dick
    robber, rbrewer, Vonzemo and 6 others like this.
  17. edcodesign
    edcodesign
  18. jnaki
    jnaki
    upload_2021-1-29_4-34-46.png 1962
    Hello,
    While reading an old Drag News from the old days, I came across a small ad for “Glamour Wrinkle Colors.” It was an ad for a surface coating that would highlight any valve cover or any metal surface. The perfect solution to a surface protecting coating. It certainly sounds like today’s term for powder coating that has seen its use many times over in hot rod building.
    I can remember the time spent inside of the warm den that we had built on to our tiny Westside Long Beach house. It was a small U-shaped house about 800 sq ft. with the addition of a large brick patio in the “U”, that small approximately, 800 sq ft house turned into a larger home with two sets of French doors leading into and out of the newly constructed den. There was also a door leading to our bedroom and another one leading into the kitchen. Finally, huge sliding glass door was showcasing the rear yard and rumpus room that became our backyard garage.
    From those cold nights when working in that rear backyard garage was too cold, I found myself working on those finned valve covers of our 283 SBC motor with some rubbing compound, mild sand paper, steel wool and polish to get a good contrast between the shiny covers and the area in between the fins.
    upload_2021-1-29_4-35-35.png similar to our 292 SBC motor
    We never thought of our shiny valve covers to make into a mini soap box derby race vehicle. We tried making a real life size soap box derby roller, we had the basic layout, but we never finished it. When these valve covers had some popularity, that we could do and get involved.
    Jnaki
    The usage of the plentiful inexpensive used valve covers could be had from any old junkyard/surplus yard. The tire/rim combination would have high speed ball bearings in the rims. The same ball bearings were the style used in constructing our 1/24 & 1/32 size slot cars for drag racing and road courses. Every advantage helps in both activities. But, real life took over.
    Valve cover racing is a competitive event similar to the Pinewood derby, but vehicles are made from a valve cover from an internal combustion car engine, rather than of wood blocks. Valve cover racing is most commonly seen at car shows.
    Rules for Construction of Valve Cover Race Car:
    · No engine, propulsion, or moving weights. Gravity is your friend. (weights must be secured)
    · Valve cover must be GM, from either a small block (283, 327 Cu. In.) or a big block (396, etc.)
    · The valve cover must retain its original gasket sealing surface.
    · The race car can have a chassis, but nothing may extend beyond the gasket surface on the front of the race car. This applies to the wheels also.
    · There is a maximum of 4 wheels allowed, either inside or outside of the valve cover
    · The race car must be clean (no sludge). If the race car drips oil or grease, it is disqualified.
    · The dimensions of the race car are as follows: Maximum Length = 30 inches Maximum Width = 10 inches Maximum Height = 9 inches Maximum Weight = 8 pounds (official digital scales at the event will govern)
    Maximum Wheel Diameter = 4 inches
  19. edcodesign
    edcodesign
    Like these?
  21. I no longer own the Coleman Coupe. It now belongs to 31Slim here on the HAMB.
  22. Joe Troilo
    Joe Troilo
    Oh those back road rides.
  23. Got some event t-shirt artwork this week from my friend B-Scott featuring a couple other good friends HAMB-friendly cars.
    Jigger, vintage56, oldsjoe and 33 others like this.
  24. I pulled an old AMT 3 in 1 62 Buick model from my hoard. I’m gonna try and build it. Hope to have it finished for next week. Box and instructions has some cool H.A.M.B. Art. Ron....[​IMG][​IMG][​IMG][​IMG][​IMG]
