Technical French Flathead
Discussion in 'Traditional Hot Rods' started by JLford, Oct 17, 2011.
  1. JLford
    JLford
    from Sudbury
    Does anyone know a website that still sells the French v8 flathead surplus?
  2. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    sfflatheads.com
  3. ventilo
    ventilo
    we try to get another batch of low mileage French flatheads from France soon, but sorry: no website
  4. customrod48
    customrod48
    try Motor City Flatheads out of Detroit......
  5. skwurl
    skwurl
    What is the advantage(s) of a French flathead
  6. swissmike
    swissmike
    They are on average 30-40 years newer and the likelyhood of getting a bood block are much higher. Casting quality is better with less core shift and supposedly higher nickel content.
    Blocks have the older style 59A shape with bellhousing, but have the later 8BA decks for better water flow. Here is some info on them:
    http://flatheaddrag.com/french.html
  7. davidbistolas
    davidbistolas
    The exhaust smells of croissant, and when you park it next to an american flathead, it acts all snooty. The american flathead with then make a WWII we-saved-your-ass comment.
  8. Jimmy2car
    Jimmy2car
    from No. Cal
    Good one David
  9. flathead okie
    flathead okie
  10. daddio211
    daddio211
    roflmao!
  11. haha, the french are funny!!!
  12. Zombie Hot Rod
    Zombie Hot Rod
    from New York
  13. SmoKerch
    SmoKerch
    A disadvantage is that they will only go in reverse if you put both hands in the air.
  14. fenderless
    fenderless
    from Norway
    As said, better overall quality, higher nickel content.
    The casting as much better, the finish is smoother.
    When you start working on it, you will see the difference right away:)
    If you buy one, you might want to change the cam, lifters and valves!
    In some of them, you must do a porting job, but that's the fun job:D!
    It comes with an aluminum cast oil pan, and alu, timing cover.
    Taildragger&fenderless
  15. the vonstripers
    the vonstripers
    from france
    there's 2 differents sizes in french flathead a 239ci and a 255ci, boths are from an army little truck, so take care from the flywheell it's heavier than a passenger car engine.
    the 255ci is a 4" stroker, it's a very good block, but you'll need to change the oil pan, the distributor, and the manifold, don't forget the porting for better flow.
    here's a good link from my friend peter
    http://www.rods-customs.com/forum/viewtopic.php?f=7&t=34
    sorry it's not translated, but pix can talk.
    the same things, with a blower
    http://www.rods-customs.com/forum/viewtopic.php?f=7&t=5557
    hope you will find what you need to know about the french flats
  16. Jalopy Banger
    Jalopy Banger
    from Sweden
  17. Jalopy Banger
    Jalopy Banger
    from Sweden
