French flathead oil sender question.
Discussion in 'The Hokey Ass Message Board' started by hotrod-kenny, Apr 4, 2010.
  1. hotrod-kenny
    hotrod-kenny
    Does anyone know where to get an oil pressure sender/gauge that fit the french flathead? I'am not shure what tread size or if it's metric or inches.
    Maby someone here knows?
    also there has to be some kind of split, so I get an oil line to the filter.
    thanks for any help!
    Kenny.
  2. propwash
    propwash
    from Las Vegas
    I have no idea - but I'll bet it's metric - try a Renault sender and gauge or Peugeot - or a French forklift
  3. Flat Ernie
    Flat Ernie
    Tech Editor
    It probably isn't metric, actually. Most of what I know about French engines is second-hand (despite owning a French block), but everything I've found says the engines stayed imperial through their production. They did use studs for mounting damn near everything - the side that went in the block was imperial, the side that stuck out was metric.
    It is probably US NPT...
  4. BrandonB
    BrandonB
    from nor cal
    Check with SoCal Sacramento. The owner bought out the inventory of French flatheads and they should know the answer to any of your questions.
    <cite>www.[B]so[/B]calsac.com</cite>
    1715 Del Paso Boulevard
    Sacramento, CA 95815-3016
    (916) 924-9744
  5. HotRodMicky
    HotRodMicky
    It's US npt
    Michael
  6. fenderless
    fenderless
    from Norway
  7. hotrod-kenny
    hotrod-kenny
    Thanks everyone!
    Takk for hjelpen fenderless!
  8. mart3406
    mart3406
    from Canada
    It's probably ordinary North American standard NPT and
    not metric. Metric pipe thread fittings - ie - ISO fittings
    - use a metric straight 'bolt-style' thread but with rubber
    or neoprene o-rings added to affect a pressure-tight seal.
    If it's a threaded, pressure sealing' location and the
    threads appear to be tapered and there's no machined face
    or slot for an o-ring, it'll be NPT. Hope this helps.
    Mart3406
  9. hotrod-kenny
    hotrod-kenny
    Thanks! I will visit my supplier tomorrow, and se what they have.
  10. ventilo
    ventilo
    If you need a sender drop me an e-mail.
    I've got some original French army spares since I'm runnuning a mechanical oil pressure gauge on my French flathead. Don't know however whether they would suit your gauge.
  11. hotrod-kenny
    hotrod-kenny
    Thanks for offering Ventilo! but I got a T- split yeasterday, and I'am using a mechanical gauge now. Works fine!
  12. HotRodMicky
    HotRodMicky
    Did you ever tried that electical sender?
    I think it`s just a switch to turn on a light.
    Should work ,too
