I have a Franklin 10B tube axle. This is one of the axles that were used on early lakes cars. The Chrisman #25 dragster, which was an early lakes car before being extended for drag racing, used a Franklin axle. This axle has the hubs which are difficult to find. The 10B is a more stylish axle with a slightly forward and downward sweep to the tube. The spring pads have been moved once but if you are using this for a 3 springer they have to be moved anyway. The pitman arm mount was cut off and is missing. I also have the sway bar for it.
