Fram filters nightmare story.
Discussion in 'The Hokey Ass Message Board' started by Pir8Darryl, Sep 20, 2008.
  1. 5window
    5window
    I've run Fram filters in most of my vehicles for over 40 years with no problems-and 175-200000 plus miles on several daily drivers.
    I'd like to see this thread parked. It's just one of those things people won't agree on so it really doesn't serve a purpose.
  2. Jason455
    Jason455
    Frams are on our daily drivers and work fine. I even have the oil changed at walmart. Haha chew on that. I hate changing oil on fwd cars.
  3. wombat barf
    wombat barf
    from oklahoma
    my own experience:
    A Fram PH8 and a WIX 51515 are both correct applications for the 260 V8 in my Fairlane.
    When the two filters are both unused they weigh about the same.
    When I change them after use on my Fairlane at the same interval the WIX is always heavier and I have always attributed that to the greater filtration rate of the WIX.
    I like the hell out of WIX BUT I make damned sure I change them when their interval is due. I have never had a WIX clog and I understand any filter can clog if left unchanged for too long.
    personally, the only filter I ever had clog on me was a Fram on a '64 Dart 170 slant six and, to be totally honest, it was the filter that was on a car that had sat for a number of years when I bought the vehicle.
  4. I'll say it one more time,,FRAM is JUNK,
    A lady friend just bought a clean,used Toyota Tercel,,65,000 miles & shes had it about 2 months---*nice* used car.
    She's been calling me saying its making engine 'noises' & shes had it towed home twice in the past 3 weeks for fear of it blowing up.
    Every time I go over there to listen to it,it sounds fine.
    (but I believed this ladys story).
    I finally went over there this morning & poured a qt. of ATF in it & drove it around for awhile & then home,,no noises.
    Ran it in the driveway for 30 minutes or so,,no noises.
    Went & got new 10/40 Valv & a WIX filter.
    Drained the oil.....when I took the FRAM filter off,it was oily inside,but there was NO oil in it,,,,I couldn't even pour any out of it.
    I shook the filter trying to get it to drip oil,(it wouldn't)& the whole inside of it is rattling around,,,up & down & side to side.
    My guess it that the internal workings of the filter were randomly coming loose & causing the engine to intermittently lose oil pressure.
    Problem solved with the WIX filter,& the engine is really quiet.
    (Probably didn't do it any good tho)
    I happened to notice a sticker under the hood from early Nov when she had the oil changed,& the FRAM filter was pretty clean externally.
    You couldnt PAY me enough to use a FRAM filter ever again.
    (Theres a spinoff thread on this FRAM issue that's been 'closed' but if you search it out,you can still read it,,,its pretty interesting especially when a FRAM "rep" chimes in)
