Found a 1931 model a coupe, 5w
Discussion in 'The Hokey Ass Message Board' started by slackcat, Jun 10, 2013.
  1. As the title says I found one close by and in good shape. If this deal turns out good, I'll have a hundred questions on my build.
  2. go-twichy
    go-twichy
    they're all 5 windows. hope you can get you're hands on it. I sure enjoy mine.
  3. Yeah, that's right.
    What are some of the things to look for as far as weak points and problem areas?
  4. scrap metal 48
    scrap metal 48
    Everything is replaceable and there's a ton of info on " how to replace".. The more complete the better and a title is good to have...
  5. VoodooTwin
    VoodooTwin
    from Noo Yawk
    As complete a body as possible is the most important thing. Everything else is likely unusable and will be upgraded if you're planning to build a hot rod out of a stocker. So buy it for the body more than anything.
  6. manyolcars
    manyolcars
    This Model is truly a traditional hotrod with its A engine with hi compression head, dropped A axle, This one has been thru 4 states in the 16 years I have been driving it. Its all A except the transmission and brakes, 35 rims. Dont believe that part about everything is 'unusable'
    nota by farmgate, on Flickr
    oops wrong picture
    myA by farmgate, on Flickr
  7. Cool A manyolcars.
    What transmission and brakes are you running?
  8. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Very nice Coupe.
  9. Old-Soul
    Old-Soul
    Depending on which direction you want to take it, like manyolcars said, everything is usable. And even if you don't want to use it, it's worth $ to someone!
    they're so simple, I wouldn't sweat too much over "things to watch out for" (just don't spend crazy money on junk!) as everything is available either new or second-hand fairly easily.
    Good luck!
  10. jfreakofkorn
    jfreakofkorn
    nice coupe ..... and let the question(s) roll =)
  11. Well I didn't buy the '31 but picked up a really nice '29 Special coupe. For right now I think I'll just drive it as is. Wife really likes it and I can find another to make a banger hot rod. I really don't have the heart to mess with this one.
      193.4 KB
      235 KB
      483 KB
  12. As far as I know they still don't repro quarter panels on these. But really, almost everything else you can get, so as long as the body is straight and not too rusty it hardly matters what else is wrong.
  13. Rattleon
    Rattleon
    from Idaho
    In answer to your earlier question on what to look for as far as weak/problem areas on a model a coupe, I would have say for a project car the more complete the better, even though most everything you can get repop! and watch for the usual lower rust problems and maybe stress cracking behind 1/4 windows around belt line.
    Your '29 special looks clean! I agree leave it and find a coupe or roadster or even one of those c-dans:D to hot rod!
  14. go-twichy
    go-twichy
    sometimes the rear sub-rails are rotted out, your little blue coupe looks good. sometimes the vinyl top can hold in water and rust out the body. good luck to you.
  15. Cool special! Looked at really killer one a few weeks back and it looked like it was right out of the 60's with the paint and 348!
  16. edwardlloyd
    edwardlloyd
    from Germany
    Not all of them!
  17. The black one is a slant windshield too !!! Neat
    A crafty fella could build that
