Hot Rods Forty Ford Fixer upper
Discussion in 'The Hokey Ass Message Board' started by Silva, May 21, 2019.
  1. WB69
    WB69
    Just Wow. That white wire looks just a tad long.
  2. Silva
    Silva
    from TX
    lothiandon1940 and Stogy like this.
  3. Silva
    Silva
    from TX
    The matchbook was in the ashtray.
  4. Silva
    Silva
    from TX
    Ok, next item : repair engine oil leaks. I replaced the finned valley cover with an OEM part, Removed the road draft tube and replaced with a PCV kit from Centerville auto repair. Pulled the intake manifold cleaned it up, painted and reinstalled with new gaskets.
    Replaced leaky valve cover gaskets
    I rebuilt the factory distributor and performed a complete tune-up. Fabbed a quick battery hold down.
    Really nothing extraordinary, just an example of whats usually expected to get an old car roadworthy.
    Video below: 59 Buick 401 Nailhead, Howards camshaft, glass paks.
    https://www.youtube.com/embed/DLbyHoffTFY
  5. The37Kid
    The37Kid
    Nice project, you started this thread on Wednesday but in reality how long have you been working on the '40 ? Bob
    Stogy likes this.
  6. Old-Soul
    Old-Soul
    I don't remember wiring your car...:rolleyes:
  7. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Great looking car, congrats! Man it sure had some deferred maintenance. Can't believe someone racked up years of driving on that wiring! Good to see you're getting it systematically sorted out.
    Swap out that plastic fuel filter for a metal one. They're known for cracking upon vibration which can quickly lead to a fire.
    Stogy and Silva like this.
  8. Silva
    Silva
    from TX
    I've had the car a little over a year now. Most of the work has been accomplished in the last few months though...
    Stogy and lothiandon1940 like this.
  9. Silva
    Silva
    from TX
    I've been driving the car more lately and making mental notes.
    Chassis, engine and transmission updates are forthcoming...
    One of the little things that has really bothered me is the hood fitment. So I took the hood off to test a theory on its effect of engine cooling. It definitely is trapping heat, car ran noticeably cooler in traffic with the hood off.
    The car has aftermarket hood hinge assemblies and I wonder if this is a contributor to the lousy fit ?
    I left the hinges off to check the fit of the hood at the cowl. Fit is greatly improved and latches no problem.
    Maybe the sheetmetal isn't as off as I thought? Aftermarket hinges crap? to be further investigated...
    With hinge assemblies in place.
  10. klawockvet
    klawockvet
    Getting the hood and grille to fit right on a 40 Ford is perhaps the most frustrating thing I have ever attempted in my long life. I finally settled for a B grade job to get the damn thing running. Kube on the Ford Barn is a great resource for doing it right. I tried to follow his advice to the letter and finally got it "good enough" but still not up to fine point standards. The last two pictures of the OP car looks about as good as a normal human can get.
    kidcampbell71 and Stogy like this.
  11. 50313.jpg Check with olscrounger on here when you start attempting to fit the hood. Him and his wife have built a number of '40s and have it down pat. This is his avatar............
  12. Knghtcadi
    Knghtcadi
    Glass packs?
    Stogy likes this.
  13. Silva
    Silva
    from TX
  14. alchemy
    alchemy
    Yes, repro hinges are no where near as good as original. Find some originals and adjust the hood to fit the cowl. Then move the fenders to fit the hood.
    For the cooling, make sure you have the little side shields between the front fenders and radiator. And a lot of guys close off the top grille brace and seal it up against the radiator too. Then all the air has to go through the radiator.
  15. olscrounger
    olscrounger
    sent you a pm-I have 3 sets of side shields if you need some
  16. desotot
    desotot
    I had a 425 nailhead leak oil. Thought it was the valley pan , then I thought it was the valve covers. I finally called the Buick guy in Centerville California. Turns out its the head gasket. An oil passage that goes from the block to the head to feed the top end. The Buick guy says if the engine is assembled with felpro head gaskets they leak sideways toward the intake. The fix is to replace the Felpros with steel head gaskets. . Of course he sells them but won't ship to Canada. I want 3 sets. Any way don't chuck the custom valley pan yet.
    P.S, nice car!
    Stogy likes this.
  17. Silva
    Silva
    from TX
    Thanks for the info. The leaks have been sorted with stock valley pan, new valve cover and valley gaskets.
    dwollam, lothiandon1940 and Stogy like this.
  18. Silva
    Silva
    from TX
    After our last drive on the "Treaty Oak" rod run, I decided to start addressing engine and drivetrain issues. So last weekend I pulled the engine and teardown will begin this week... stay tuned.
    With the engine now out of the car, I pulled the clutch and flywheel to facilitate installation on the engine stand. I found this!
    After speaking to one of the previous owners, I found out that the "Wilcap" alloy flywheel had recently been serviced by "Mcleod" with a new steel insert and a rebalance. The result is very disappointing.
    The insert was installed off center and one side is also tipped up causing the burnt flywheel/clutch situation... eccentricity has no place in this situation!
  19. J. A. Miller
    J. A. Miller
    from Central NY
    Wow - that's not good! I would have expected better from Mcleod. I hope you can save it.
    Silva and lothiandon1940 like this.
  20. MIKE STEWART
    MIKE STEWART
  21. MIKE STEWART
    MIKE STEWART
    cool ash tray !
    Silva likes this.
  22. Silva
    Silva
    from TX
    First of all a huge thank you to @olscrounger for reaching out with advice on front sheetmetal fitment and for providing some sheetmetal parts to aid in engine cooling. Super nice guy!
    I have the engine disassembled and in the clean, inspection stages... I'll keep y'all posted!
  23. olscrounger is a top notch guy and knows '40's inside out. And his wife probably knows more about them than most folks on here. She's right there when it comes to aligning that difficult front sheet metal.:)
  24. dirty old man
    dirty old man
    I agree 100% he has been a fountain of knowledge for me also, especially in the parts, pieces and techniques to move the battery to behind the right front tire. What are those 2 sheet metal pieces and where do they go?
    lothiandon1940 likes this.
  25. alchemy
    alchemy
    I also need to thank olscrounger in the parts and advice department. He's probably built more 40's than I've ever touched.
    kidcampbell71 and lothiandon1940 like this.
  26. gigem
    gigem
    Howdy neighbor! I'm in Lakeway.
    Car looks great, hope to see it on the road up here some day.
    Sent from my SM-G935V using Tapatalk
    Silva likes this.
  27. olscrounger
    olscrounger
    Thanks all--always willing to help get another 40 on the road! Now gotta find me another one-the hunt is on.
  28. Mr48chev
    That looks a whole lot more like someone in the past using the clutch pedal as a foot rest than a manufacturing issue.
    Great thread and those first photos of the car being loaded and unloaded sure make that car look familiar as from an old magazine photos.
  29. If you want more info on the origins of this hot rod, Paul Aldrich is still banging around at his shop, still getting grease under his nails, and doing well. I last saw him in April at our annual flea market/show in Fitchburg......we both are members of the New England Regional Group.
    kidcampbell71 and Silva like this.
  30. 100% Matt
    100% Matt
    I had my eye on this car shortly after I got my 40 Deluxe. Both previous owners are friends of mine as well. You're doing a killer job and giving this car its much needed and deserved attention! Congrats!
    Silva likes this.
