3 ford steering columns. They all are early ford with 2 being truck. The stick shift one I am not sure what it came from. This would be good to use if you are building a hot rod with a sideshift stick trans and you would like to mount the shifter on the column. The other 2 are from early ford pickups that are for automatic trans's. They both have the plastic indicators intact and the neutral safety switch. These would be neat to use with your automatic trans instead of a modern tilt column or a floor shifter while looking old. They all have the turn signal parts intact. All plus shipping.
