Technical Ford Speedometer Drive Question
Discussion in 'Traditional Hot Rods' started by FlatJan, Mar 4, 2018.
  1. FlatJan
    FlatJan
    Hi Gang,
    I want to run a closed drive line banjo on an AV8 with a Ford speedo.
    how do i know which speedo drive to choose?
    There are 18, 19 and 21 teeth as far as i have seen.
    i guess it depends on the differential ratio and tire size?!
    Which combinations needs which turtle?
    thanks guys´n gals
  2. alchemy
    alchemy
    They aren't expensive, so grab one and give it a try. Then you will know which way you need to adjust, if possible. You might find that none are gonna get it perfect (I did). You might need an inline ratio change box. A good speedo shop can make a box that will give you a perfect reading speedo.
    The gear on the driveshaft is the same for all the turtles.
  3. FlatJan
    FlatJan
    ok will do
    thanks alchemy
  4. The Green Bible has a table showing which one you need for stock ratios and tires. If you post your rear end ratio and tire size maybe someone could help. The turtle should match the teeth on the gear.
    Charlie Stephens
  5. topher5150
    topher5150
    I have a turtle assembly, and the worm gear if you still need one. I'll have to double check the number stamped on it.
  6. alchemy
    alchemy
    Yes, you don't pull the gear out of the turtle. You just switch out the whole turtle. Each turtle housing has a gear centerline a bit different from the other to make the driven gear spaced properly from the driveshaft.
  7. FlatJan
    FlatJan
    @Charlie Stephens: i found the speedometer cable table but not the one for turtles. i can see it referenced as " speedometer gear chart" but where is it hidden?
    thanks
  8. Look on page 632 of the Green Bible.
    Charlie Stephens
    FlatJan likes this.
  9. FlatJan
    FlatJan
    thanks charlie i have an old original Ford chassis catalogue. it doesn´t have that page..
  10. Bruce Lancaster
    Bruce Lancaster
    I'm at work with no catalog...but try the 17,000 general part number section, where speedometers live along with other small systems. Unless using actual original sizes, try to match your tire diameter to an original size in the diameter and ratio chart.
    FlatJan likes this.
  11. Relic Stew
    Relic Stew
    from Wisconsin
    Most speedometers are 1000 rpm = 60 mph. If you know your tire revs per mile (some manufacturers have that info on their website) and axle gear ratio, you can figure out the speedo gears necessary.
    FlatJan likes this.
  12. FlatJan
    FlatJan
    thanks for the hints guys :)
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    3.78's take a 19 tooth turtle, 3.54 is 18 and 4.11 is 21. this of coarse is assuming you have stock diameter tires
  14. Bruce Lancaster
    Bruce Lancaster
    If you are using tires that are not on the Ford chart, you will need to find out diameters of the tires shown and match up your tires. This is an inexact science since tires are not all that uniform, especially over several decades, but you should be able to come close by just asking Hambers about sizes of particular tires.
  15. hightower611
    hightower611
