ford internal voltage regulator
Discussion in 'The Hokey Ass Message Board' started by pie pie, Mar 8, 2011.
  1. pie pie
    pie pie
    from missouri
    ok so im getting to fixing the wiring on my galaxie and my coolant and gas gauge do not work. tank has a new sending unit. someone said that i may want to change the voltage regulator on the instrument cluster. where can i find them to buy? have not found any yet. would there be something else i may want to check? it doesnt matter which side of the gauge the wires go to does it?
  2. jetmek
    jetmek
    try napa p/n IR-1 yes they are polarity sensitive
  3. pie pie
    pie pie
    from missouri
    what do you mean by that? i can meter through the regulator
  4. 1971BB427
    1971BB427
    from Oregon
    He means pos to+ and negative to-.
  5. pie pie
    pie pie
    from missouri
    I thought I put them back were they came from because the ends were different. If I got them switched would it blow the regular?
  6. pie pie
    pie pie
    from missouri
    Ok does anyone know what the oham is for stock Galaxie sending unit? I can get an aftermarket gauge cheaper than a voltage regulator.
