I am rebuilding a 1949 239 ford flathead and the tube that runs in the middle of the engine by the lifters (distruibtion tube) needs to be replaced.Has anybody ever done a replacement, how do you replace and where do I get the tube. thanks
They aren't designed to be removed what's wrong with yours?That isn't a lifter tube they are lubed by splash only.That is how the oil gets to the cam and crank brgs. T
It is pretty heavy-walled...I have HEARD OF, never seen or experienced, people replacing them by threading in a slidehammer and pounding away. Replacement would have to come from another '49-53 block. I doubt the 1/8 pipe threads would do the job, probably would need to tap the ID of tube farther in... Testing it would require some improv...front is 1/8 pipe, rear and down-holes at cam bearings would have to be tapped and plugged, bolt with washers and gaskets through pushrod hole in case you have the one with tiny lube hole in bushing...then grease fitting in the front and pump up some pressure with a grease gun! It should be easy to far exceed normal oil pressure numbers this way. I would probably skip all this foolishness (and the risk of cracking the block during R&R) and just hot tank, then attack pits with a pick to see what's what. I betcha it's good for another 60 or 70 years as is. You know you're in trouble if your oil system is rusting out!!
ive seen em rusted thru before...mouse piss is nasty stuff. if theres pinholes in top just try zapping with a mig if it leaks where you cant reach id say your sunk....
