Ford Flathead Generator servicing.
Discussion in 'Traditional Hot Rods' started by Archie31, Nov 29, 2014.
  1. Does any one out there have a Ford Flathead generator with a oiler cap like this? Also what kind of oil do you use to lube it?
  2. Mr48chev
    We used to just put a few drops of 30 weight in those back when they were common when we lubed the car.
  3. 4dFord/SC
    4dFord/SC
    Just let a little run off the dipstick when you check the oil.
    kadillackid likes this.
  4. Yep ^^^^ twice.
    I like the old stuff with provisions for oiling the bushings.
  5. Mr48chev
    I've done the dribble of fresh oil off the dipstick thing after changing oil too. It doesn't take a lot of oil at one time just remembering to do it on a regular basis.
  6. I think that I have used 3 in 1 oil and just filled the cup before. Done the dipstick thing as well.
  7. Bruce Lancaster
    Bruce Lancaster
    At the other end, you have a roller bearing...several types used over the years, you have a fairly late generator with a single row bearing. For reliability you want to know what you have up there...disassembly is easy, just keep track of the stack of washers and stuff. Clean the thing, replace it if it seems loose or has wear grooves, and thoroughly stuff it with good wheelbearing grease. Repeat every twenty or thirty years, you have to stay right on top of these things...
    Once well greased, it will last pretty much forever if belts are not overtightened...the big type belts are run fairly loose.
