Technical Ford FE: 352 or 428?
Discussion in 'The Hokey Ass Message Board' started by Chris, Dec 27, 2018.
  1. Man it's been a lot of years since I've worked on an FE. I have a 57 F-100 that I am tossing around the idea of a mean FE engine in. I found a truck for sale local (1965 F-350) that the seller claims had a 428 upgrade in the 70's. The original engine was a 352. Everything under the hood looks correct for a stock 352. I thought the harmonic balancer had an extra little counterweight on a 428, as they are externally balanced, but some reading I did said only the CJ engines had that. To all of you FE experts: short of measuring stroke or tearing the engine apart: is there a way to ID a 428 (or maybe just a 428 crank) visually? I thought I could by the damper, but I am not too sure now.
    CC321D5B-4A94-4D2D-B316-47705C32EFF9.jpeg 8AF29D61-E517-4105-8711-B2F544335DFA.jpeg 79585BB0-6F50-4FCA-93B3-7CFEAA8B55F9.jpeg 581F73BA-662D-440F-A10A-6FF436D8D9EB.jpeg
    loudbang and Deuces like this.
  2. saltflats
    saltflats
    from Missouri
    The 428 block will have a scratch in the casting on the back of the block. Can't remember what it is but it loos like it was scratched in the casting mold with a stick.
    And I found out that not all 428s are externally balanced.
  3. deathrowdave
    deathrowdave
    from NKy
    Is that a 2 barrel intake ? I have never seen anyone run a 2 barrel on a 428 , I have seen many 4100 Ford 4 barrels . This should be 99% of the fact finding mission . Look at exhaust manifold mounting flanges , early FE only had one set of bolts , later FEs 428 had 2 sets of flange bolt holes . My thoughts are the seller is trying to make a killing on your not knowing . I had a 66 428 cu in not a CJ or SCJ just 428 cu in , normal driving you will never know the difference in either cube . It’s complete , rebuild it , and enjoy it . My thoughts are the burden of proof is on the seller , if he can not prove to you it’s a 428 , then , It’s got to be a 352 and pay for it as such .
    Bigblue61, Spooky, bchctybob and 8 others like this.
  4. How do you do a 428 upgrade and not use 428 heads? Those don't look like 428 heads. They use a 4 bolt manifold per each exhaust port. You can run the 2 bolt manifolds but there is a bump at each port for the threaded boss near the Spark plug hole. Look close at this head.
    s-l1600.jpg You can see the bump for the bolt and I don't see any in the photo of your motor. Your right about a thicker balances not to say a machinest couldn't use an early 352 piece but,,,,,, I think he's giving ya Blow By.
    Spooky, loudbang, Deuces and 3 others like this.
  5. R Pope
    R Pope
    Tore down a few 428's, all were externally balanced. They are like Y-blocks, all are 312's till the heads come off!
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    428 will have an "A" or an"X"on the back of the block..Not forged or cast.. looks welded.
    My 66 PI is Balanced via the flywheel.... i run a stick.No weights on the bottom damper pulley.
    Unless your digging into that engine or you have it apart.... (checking the bore size)... pretty tough to see from this standpoint.
    352?... look up who Karol Miller is......
    Spooky and loudbang like this.
  7. Marty Strode
    Marty Strode
    The flywheel will have an extra weight if it's a 410 Merc or 428, they have the same stroke. Is it a stick or auto ?
    stillrunners likes this.
  8. I would try to measure the stroke through the spark plug hole.
  9. every FE is not a 360 unless I own it
    check the flywheel if possible
    FEs are kinda like SBCs
    you can swap all kinds of parts between them
    dana barlow, Spooky, Roothawg and 2 others like this.
  10. flamedabone
    flamedabone
    Lots of FEs will have 352 cast in the drivers front of the block by the water pump, don't let that freak you out. I think you should buy it, you don't have near enough cool stuff.....
    -Abone.
    loudbang, deadbeat and OahuEli like this.
  11. Jeff Norwell
    Jeff Norwell
    MODERATOR
  12. loudbang likes this.
  13. Boneyard51
    Boneyard51
    It’s hard to tell 352 from a 428 externaly. The best way is to determine if there is the 28 ounce balancing weigh cast into the standard fly wheel or added to the auto flex plate. If there it still doesn’t 100% mean it’s a 428, it could be a 410.
    As with all Fords, you can never saw “always”. But if possible you can remove the front freeze plug and it will have 428 casts in small numbers at the base of the cylinders. You can also use the drill bit test, but I forget what size drill bit to use. Sucks getting old.
    Heads will tell you nothing for sure, may indicate a 428 if they have an N following the casting number. Those will be CJ heads, but a lot of 428s came with just standard heads also. CJ heads will have more than 8 exhaust bolts.
    Almost all 428 and 410s came with 4 barrel carbs.
    Bones
  14. Sure looks like a '65 352 to me.... look here... https://www.fordmuscleforums.com/engine-articles/485052-easy-cid-measurement.html
    With that said, Ford did build some vanilla 428s for LTDs, etc that didn't have any of the 'special' hi-po bits. They even offered one in the pick-ups '69-72, but only in a 2WD with a C6. On these, they used a 'generic' damper but had the extra counterweight cast into the spacer that goes between the damper and the lower timing gear. If that weight is there, it'll be obvious. I don't see it in your pics...
    But a bit more bait... IIRC, the '65 352 truck blocks were the last ones built by Ford that supposedly could take an overbore to the 4.13" 406/428 size (after checking for core shift). That nugget is from an article I remember seeing about building a budget 428 in the late '60s/early '70s. YMMV....
    Spooky, loudbang, Deuces and 2 others like this.
  15. Boneyard51
    Boneyard51
    Dave, I usually agree with you on most things, but.... I think the difference between the 352 and the 428 are dramatic! I own a 352, 360, 390, 410, and two 428s. The 410 and 428s are awesome, really pull. The others not so much. I think that extra stroke makes the difference.
    Bones
  16. mgtstumpy
    mgtstumpy
    This is what was referred to in post #4, note NS, EW bolt pattern of 428CJ -vs- normal FE bolt pattern heads below. There are are a few other variations with 390GT heads
    Depending on YOM, Ford commenced stamping partial numbers on rear of block
    Also block casting date may assist on underside of oil filter adapter
    https://www.428cobrajet.org/id-block 15/64" drill bit is mentioned here.
    No 2v 428 according to Wiki
    FE blocks before 1965 had two-bolt engine mounts while those from 1965 and later had three-bolt engine
    mounts. 65 and later FEs had the alternator boss cast into block on passenger side
  17. Some truck blocks had four motor mount bosses...
    loudbang, Deuces and mgtstumpy like this.
  18. saltflats
    saltflats
    from Missouri
    The one I am involved with had a C on the back of the block.
    It is a 2 bolt main with the 3 webs.
    Now it is a 467 inch engine, still in the progress of building it and the car.
    loudbang, RMR&C and Boneyard51 like this.
  19. Squablow
    Squablow
    I have a Torino with what is supposed to be a '67 Thunderbird 428 in it and everyone I've asked said the only way to tell for sure is to take it apart or drop the oil pan. My engine has a lot of clear, readable casting numbers on it but none are definitive, so I'll be watching this thread, hopefully someone will come up with a good way to ID it.
    Would measuring the stroke through a spark plug hole work?
    Boneyard51 and loudbang like this.
  20. Link in post #14....
  21. Squablow
    Squablow
    Bookmarked, thanks!
  22. Boneyard51
    Boneyard51
    Steve that counter weight is behind the timing cover, a person would have to remove the cover to see it. Also it was only used on the SCJ engines to counter balance the larger rods and bolts, unique to 428 SCJ engines, the rarest of 428 engines.
    Bones
  23. Below is how the ad reads. The owner is NOT a car guy at all, I think he really thinks its has a 428...I’m actually surprised he knew the cubic inch. He says he has “documentation” of the “conversion”. By conversion, I’m guessing if anything, it had a 428 rotating assembly put in it. Heads are standard C4AE’s, everything looks stone stock 1965. The truck has a new process 4 speed.
    The problem with the truck is, it’s a really nice truck. I have no need for it, and pulling the engine out would kind of kill it unless you had another engine to pit in it. The truck is really cheap, I don’t tuink the owner is trying to “cash in” on the 428 part. I’m not going to want to go through the trouble for a 352. For a 428 I would...sounds like it’s somewhat of a gamble until I decide to get dedicated.
    FE961762-FF0D-4F56-B741-F13BC1872BA3.jpeg 8E931E79-941A-4DB7-A438-D1F20930DC0A.jpeg C6802DDC-0474-418B-822A-C24DACFA380D.jpeg 1A2C0F35-A50C-40DC-8016-105EEB7C135B.png
    kidcampbell71, loudbang and OahuEli like this.
  24. thought Ford stopped building the 'wrong beds' in 63
    anyway iy has a lot of nice parts to get rid of
  25. Boneyard51
    Boneyard51
    Chris, at some point in time some one spent some money on that truck. Custom bed, Warn winch and bumper. That tends to lead me to believe the owner a little more. That winch on the front of the truck is a highly sought after winch in the 4x4 crowd. Would be worth some bucks if it’s working, would still have value if not. Cab looks solid.
    Bones
    loudbang and anthony myrick like this.
  26. Through 65 or 66 for 4WD and weird wheelbase trucks...like this one
    Hnstray and loudbang like this.
  27. flamedabone
    flamedabone
    That thing is bitchn'. You are a wuss if you don't buy it.
    -Abone.
    loudbang, Roothawg and Chris like this.
  28. B Ramsey
    B Ramsey
    Here is the crowd that's interested in the winch. If it comes available.
  29. Any idea of a window of value? If I buy it and the engine gets pulled...unfortunately I’ll probably part it out. The truck is cool...but I looked up the gears (Dana 70) and I bet top speed is 45-50
    loudbang and Boneyard51 like this.
  30. the hood doors grille and cab would sell fast
    the fenders are 3/4 and 1 ton items
    good inner fenders and radiator supports are getting hard to find
    the old 6 lug stuff, well, most folks try to swap those out for 8 lug products
