Projects ford early flathead GUYS I NEED HELP
Discussion in 'The Hokey Ass Message Board' started by shooter_bighorn, Jan 25, 2020.
  1. shooter_bighorn
    shooter_bighorn
    I have what I believe to be a 1941 ford v8 block it.has the raised intake section on the block . cam cover has 3 holes on it ....IT CAME WITH A 4 HOLER diver helmet distrib on it ? can i use this will it work ??or should i try and source a 3 HOLER .thanks in advance
  2. chicken
    chicken
    from Kansas
    Yes, one hole is just not used and doesn't affect anything. My '41 came stock with that setup.
    Terry
  3. rusty valley
    rusty valley
    i would go after a two bolt timing cover and use the later crab distributor. easier to work on, and shorter if you are putting it in the A in your avatar
  4. shooter_bighorn
    shooter_bighorn
    yes its going in the A
  5. I have used a divers helmet distributor in my avatar for 20 years and it has performed flawlessly. Oh damn, have I just jinxed myself?
