Technical Ford clutch help for a Chevrolet guy
Discussion in 'The Hokey Ass Message Board' started by KJSR, Mar 11, 2019.
  1. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    The linkage was removed from the clutch fork, my friend attempted to move the fork fore and aft several times by hand. Whatever was jammed eventually broke loose and the bearing slid back on the sleeve releasing the clutch. The linkage was reinstalled and all worked as normal. My best guess is that it was the bearing that was binding on the sleeve but can say for certain.
    Johnny Gee likes this.
  2. whiskerz
    whiskerz
    from Ga.
    Glad to see you got it handled
  3. Ever try to slide a ring over a rod or pole real fast? Then there's placing a tight tolerance sleeve onto a shaft that won't move except by walking it then suddenly when fully inserted it slides as should be.
    KJSR likes this.
