Anyone know what year this Ford cab is? I got it with a load of other stuff a while back. It was just the cab and frame. No bed, front axle, or front cap. The engine is the Diver's Helmet" style distributor flathead. Not sure if it's the original engine or not but looks like it probably is.
Should be '40-41...pan forward a bit...if 1/2 ton, it would have cross spring. Later have oxcart springs.
So are 40-47 cabs all the same? It has a rectangular speedometer with 2 gauges built in on each side if that helps any.
There are slight differences at fenders. '41 last year for that distrib...what is front spring. cross or parallel?
