Ford bell housing Id
Discussion in 'The Hokey Ass Message Board' started by hobbyjp, Nov 28, 2012.
  1. hobbyjp
    hobbyjp
    from socal
    I picked up a ford bell housing yesterday thinking it was a Y-block car bell but after comparing it to the Y-block truck bell that I have it appears to be something else. The bell to engine top mounting holes measure 5 7/16" center to center and the bottom mounting holes measure 15 1/2" center to center. bell housing is stamped F-6394-A and has 66 in the bottom left.
    Heres the bell in question to the right of a y block truck bell
    Thanks for the help
  2. Flathead???1949-1953
  3. V8 Bob
    V8 Bob
    Definitely not flathead. Looks like pre-'65 FE (332-427) Ford. :)
  4. Marty Strode
    Marty Strode
    This one is from 63 Galaxie with a 406, I think V/8 Bob is correct. 332 thru 428, the starter location is far too high for a flathead.
  5. This is a Y block bell out of a 54' Ford. If you need it pm me.
  6. sunbeam
    sunbeam
    How about a 223 6 cyl
  7. The numbers say it's for a 66 Galaxie. From the trans mount holes I'd say an early 66 or a 6 cylinder car.
  8. hobbyjp
    hobbyjp
    from socal
    Did you take that bell off a y block or were you told it was y block bell? Im pretty sure you have a 49-53 ford v-8 flathead bell, those two ridges on top give it away. I have a 1961 292 y block and the mounting holes are far more spaced out than that bell housing. I've had earlier Y blocks but cant remember if the mounting holes for the bell housings were different in the earlier years, I remember them always being the same.
  9. hobbyjp
    hobbyjp
    from socal
    Those 60's Galaxie ones are slightly different than the one I have. heres another pic the mounting holes by the clutch fork are different and the starter looks close but also looks a little different too.
  10. I got it from a friend of mine who told me it was for a Y block. I just wanted the clutch fork so I never questioned him. I could be wrong.
  11. V8 Bob
    V8 Bob
    Definitly not Y-block. Looks to be '52-'53 F/M flathead.
  12. TomP64
    TomP64
    from Vancouver
    The top two FE mount holes are more like 6" apart so it isn't that.
  13. I cant tell you what it fits but I can tell you the part number
    Its part# C2TZ 6392 A OR C2TZ 6392 B
    Its for a 1962 Ford Truck.
    This is based on the cast 6394 and cross referenced in the Ford MCR
    Oldmics
  14. V8 Bob
    V8 Bob
    Ford light trucks, starting in '53, began using the bell housing as a rear engine/trans mount, and have mount "ears" cast into them. The bell in question is not truck.
  15. Correct. And also the trans bolt pattern is for a car type 3 or 4 speed.
    I think it is a 6 cyl bell (223).....will check one I have today and compare.
  16. lukey
    lukey
    Got one I took off a y block if you need one pm me
  17. lukey
    lukey
    ImageUploadedByTJJ1354205326.696698.jpg ImageUploadedByTJJ1354205342.595995.jpg
    Don't know what year, but I pulled this off a 292
  18. thekasa
    thekasa
    What do you want for the Yblock bell h. ?
  19. thekasa
    thekasa
    I'm interested in it. send me a note.
