i have a aod in my shoebox that won't shift .i already set the tv cable correctly my question is if i put a cheap filter in it would it cause it not to shift
Maybe some more information might help. Was it working properly before the filter change or is this a new installation?
All I did was put all the stuff that comes with the lokar shifter and kick down cable i did have to open the pan to switch the shifting lever from down to up Sent from my SM-G935P using The H.A.M.B. mobile app
Yes it was working before I put the lokar stuff on it .this is the second aod trans i got and the same problem .I did use the brand of filters on both trans am i missing somwthing Sent from my SM-G935P using The H.A.M.B. mobile app
It's odd that the two trans are doing the same thing Sent from my SM-G935P using The H.A.M.B. mobile app
This old thread from the HAMB might help. https://www.jalopyjournal.com/forum/threads/shift-problems-with-a-ford-aod.169708/
