Ford 9" rear end tag identification
Discussion in 'The Hokey Ass Message Board' started by BrownCow1992, Jan 15, 2014.
  1. BrownCow1992
    BrownCow1992
    from joliet il
    Alright I have a 1963 unibody and I have what I beleive is the tag from the original axle on the truck. I hope someone can help me Im trying to figure out what spline the pinion is whether it's 28 or 31 need help I.d. the tag it reads
    WDC-CA4 1MG
    2.75 9 116A
  2. BrownCow1992
    BrownCow1992
    from joliet il
    1MB not 1MG
  3. 270dodge
    270dodge
    from Ohio
    WCD- CA4 indicates a 67-70 28 spline.
  4. 270dodge
    270dodge
    from Ohio
  5. squirrel
    someone swapped gears, if it has those 2.75s in it. Not what you'd find in a truck back then.
  6. BrownCow1992
    BrownCow1992
    from joliet il
    I havent taken the rear end apart im having a friend do it but I have to order parts for it but your thinking that's not a gearing for a u nibody that had a 223 in it?
  7. Scumdog
    Scumdog
    A 223 6 with 2.75 gears?
    It wouldn't even be able to get out of its own way, it would be seriously s-l-o-w...
  8. squirrel
    if you can get a few pics of the rearend it might help ID it. The tag may or may not be helpful....could be that someone swapped a later model center section into the original housing, or maybe they swapped the whole rearend. There are subtle visual differences, some guys can spot right away what you have just by looking at it. They're mostly guys who worked in junkyards years ago....
    also when buying parts for Ford 9" rearends, it's usually a good idea to get replacement parts that match what you have, rather than trying to get them based on what year/model the rearend is. Although you kinda have to know what years/models used what parts...since modern parts stores are based on computers that go by year/model.
