Technical Ford 9" rear axle
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Nov 29, 2021.
  1. I'm sure a lot of you have changed the center chunk (carrier) in a 9" Ford axle, I have never changed one but I am planning on removing the 4.11 chunk and replacing it with a 3.25 which my pal Randy Nash gave me several years before he passed away.
    Is this as simple as removing the 4.11 and replacing it with the 3.25? HRP
  2. squirrel
    As long as the spline count is the same, and the pinion yoke is the same, yeah. And then change the speedometer drive gear.
    If the pinion yoke is wrong, you'll need to swap them, but you have to make sure the pinion bearing preload is correct when you're done. Fortunately you can remove the pinion support to do this work, just make sure to keep the shim the same, and perhaps replace the O ring and possibly the crush sleeve, if it uses on.
  3. Hopefully the 3.25 has been stored well, and is not rusty or dirty. Squirrel covered it well, and replacing the crush sleeve is the preferred method if you change the pinion yoke. If you are not comfortable doing that, I have used another method in the past that has worked well. Set up a dial indicator on one of the ring gear teeth, and while holding the pinion still, rock the ring gear back and forth from contact to contact on the pinion tooth to get a backlash reading. Swap the yoke, and tighten the yoke nut to about 50 ft lbs. Check the backlash again the same way, and tighten the pinion nut in 10 lb increments until the backlash is the same as original. The pinion should also have a very slight drag on it when you turn it after being done, indicating there is some preload on the bearings. If you do pull the pinion assembly, I think 3.25 is a ratio that does not require gear timing.
  4. RmK57
    RmK57
    If you don't feel comfortable or want to bother messing changing a pinion yoke you could always buy a combo u-joint. They make a quite a few different styles to suit most any oddball or non-oddball setup.
    Texas57, Joe Travers, 3W JOHN and 6 others like this.
  5. squirrel
    the combo Ujoint will work for different size Ujoints, but not for different length yokes....and there are different length yokes.
  6. jaracer
    jaracer
    Once there is zero play in the pinion bearings, which can be obtained with no pinion bearing preload, tightening the pinion nut has no effect on backlash. The tightness of the nut only affects pinion bearing preload and that is what is important.
    SOHC427, Hnstray, 3W JOHN and 4 others like this.
  7. gimpyshotrods
    gimpyshotrods
    One thing to check on is fill and drain plugs:
    I once encountered, and it might have been an 8-inch, that had to be filled through the axle vent, due to mismatched parts.
  8. squirrel
    That filler plug problem exists with 9" rears, also....good catch
    olscrounger, Hnstray, 3W JOHN and 6 others like this.
  9. RmK57
    RmK57
    Yes. I think there are two lengths, long and short. I remember I had to change to the short yoke when I swapped over to the larger Daytona support.
  10. Boneyard51
    Boneyard51
    Buy a set on new copper washers , usually the ones you take off get damaged! Not always, but if your luck is like mine……they will! :(
    Bones
  11. Mr48chev
    The axle spline count can be a big deal. More than one guy has run out and snagged a 4.11 Locker out of a F150 and found out it wasn't going to be a direct bolt in in his 28 spline rear end.
    I remember the fill plug thing too. a buddy of mine ended up drilling the housing and welding a bung in it for a fill plug. I just remember him cussing about having to take the rear end all back apart after he got it together and couldn't put gear oil in it.
    Deadbird, 3W JOHN and HOTRODPRIMER like this.
  12. gimpyshotrods
    gimpyshotrods
    Yeah, trying to force gear oil into the vent hole while my boss was screaming at me to hurry up seared that into my memory forever.
  13. I found it was easier to jack up one rear wheel, pull the axle and squirt the gear lube in there....
  14. poco
    poco
    from oklahoma
    Crazy Steve has it right
  15. That worked OK for an initial fill, but if you had a leaker it could be a real pisser trying to figure out how much to add... Good test of your axle seals.... LOL
  16. squirrel
    might make you want to remove the center and drill and tap a hole for a fill plug, eh?
  17. Deuce Daddy Don
    Deuce Daddy Don
    Thats the racial I went to!----You'll like it too!
  18. That ended up being the final solution....
  19. RmK57
    RmK57
    May as well drill and tap the housing for a drain plug while your at it.
  20. GordonC
    GordonC
    If I can piggy back on HRPs post without offending him? I have a 1975 Bronco 9 inch in my A which is supposed to be a 3:50 posi (trac lock?). Both wheels do turn in the same direction at the same time when up on jacks. It clunks backing up, around turns, and generally is a noisy pain in the ass. Is the simplest solution to pull the whole center carrier and swap a new one in (which isn't posi or trac lock) or is there something I could swap out to make it more street friendly. My flattie may have 150 HP so I really don't see a need for this rear end on a strictly street car.
    SDS, 3W JOHN, HOTRODPRIMER and 2 others like this.
  21. @GordonC
    Try changing the lube; it's worked out for me in the past.
  22. Blues4U
    Blues4U
    from So Cal
    I have a 3:23 ratio diff in my Model A, it seems like a good blend of highway/performance gearing. With 29" tall tires and non-OD trans the engine seems happy to cruise at 70 - 80+ mph.
    3W JOHN, HOTRODPRIMER and GordonC like this.
  23. GordonC
    GordonC
    Blues4U I am ok with the 3:50 gear just not having a rear end that seems locked. My trans is a top loader 4 speed from a 66 mustang which had a 3:25 rear in it. I have rear tires that are close to 31 inches tall. Thanks though.
    Algoma56 thanks. Will try it.
    3W JOHN, HOTRODPRIMER and Blues4U like this.
  24. Boneyard51
    Boneyard51
    Like mentioned change the oil and put the Ford additive in with it. Or if too difficult to change just add the additive. Then take your car and turn it 10 tight as possible turns to the right, then the left. Your Bronco “ posi-trac” ( trac-loc) will be smooth as silk! Unless some swapped in a Detroit locker ! Lol
    My 1968 Bronco sounded like gears were crawling over each other, until I did the additive and turns!
    Bones
  25. GordonC
    GordonC
    Thanks Boneyard51! I'll give it a try. Easier than pulling the carrier!
    Boneyard51, HOTRODPRIMER and 3W JOHN like this.
  26. 3W JOHN
    3W JOHN
    Good idea!
    Boneyard51 and HOTRODPRIMER like this.
  27. No problem at all brother, this might help someone else with a problem. HRP
    3W JOHN, Boneyard51 and GordonC like this.
  28. flamedabone
    flamedabone
    If you accidentally drop the center section into your drain pan full of 90w, you will wish you hadn't.
    -Abone.
  29. DDDenny
    It's a rite of passage!
  30. Blues4U
    Blues4U
    from So Cal
    That sounds like the voice of experience! :D
