Technical Ford 9 Inch Rearend I.D.
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Aug 25, 2019.
  1. Speed Gems
    Speed Gems
    My uncle is tearing apart a Ford rearend for a new project. He knows it's a 9 inch be want's to know what it's out of, what gears it's got and so forth. I didn't get any pictures of it but he said it had brass washers behind each bolt. And the tag reads WDG-EL 7GD And the bottom line reads 2 50 9 040A. Thanks for any of your help in identifing thid rear end. 68972140_2845140468834784_2409117877257895936_o.jpg
  2. woodiewagon46
    woodiewagon46
    from New York
    According to the paperwork I have, WDC-EL, signifies Ford and Mercury vehicles from '77 & '78. 2.50 Ratio, the 040A is the assembly plant. I don't know what the 7GD is, the book states "Number shown only when it affects interchange" and the 9 is the date code, It also lists that the axles have 28 Splines. The brass washers are sealing washers to prevent gear oil from weeping thru the threads. Perhaps someone else can tell us what the 7GD means.
    1Nimrod likes this.
  3. squirrel
    WDC maybe?
    77-78 Ford big car, 2.50 ratio
    WDC-EL Ford Pass. 77 2.50 9.0 NL 28 -
    Ford Pass. '78, to 3-15-78 2.50 9.0 NL 28 -
    Ford Pass. '78, from 3-15-78 2.47 9.0 NL 28 -
    Mercury '78, to 3-15-78 2.50 9.0 NL 28 -
    Mercury '78, from 3-15-78 2.47 9.0 NL 28
    1Nimrod likes this.
  4. Speed Gems
    Speed Gems
  5. Mr48chev
    This is the easiest to use and most complete Ford rear axle tag ID page I have found.
    http://fordification.com/tech/rearends_ford01.htm
    Page 2 half way down verifies what Woodiewagon and Squirrel already posted.
    1Nimrod and Hnstray like this.
  6. Mr48chev
    1Nimrod likes this.
  7. squirrel
    it's difficult to read rusty old tags, you know.
    1Nimrod and Speed Gems like this.
  8. Sounds like some good Bonneville gears.
    Old wolf likes this.
  9. Mr48chev
    1977 gas crunch gas mileage gears. Couldn't pull a sick whore off a pot with the but you could cruise at 85 with a 55 mph speed limit all day.
  10. Boneyard51
    Boneyard51
    What are those 8 3/4 rear ends? I’ve heard of 8 inch and 9 inch even 9 3/8 but never 8 3/4.
    I guess those 7 3/4 were those four bolt Falcon six cylinder car rear ends?
    Bones
  11. Speed Gems
    Speed Gems
    @Boneyard51 I think the 8 3/4 may have been DANA rear ends maybe, because i think a lot of them went into Dodge pickups too.
    1Nimrod and Boneyard51 like this.
  12. Boneyard51
    Boneyard51
    Ok, I went back and looked at the whole post and saw 8 1/2 , 7 inch 7 1/2s ....all different kinds of rest ends! I imagine your right, Ford used several Dana rear ends.
    I’ve got one, in the barn , out of 1960/70s Ford pickup that is a Dana 60, 3:54 Traction lock, but has 1/2 ton, 5 on 5 1/2 bolt pattern. Only one I’ve ever seen, I know there out there, but this the only one I’ve encountered. And I have pulled a lot of rear ends out of Ford pick ups.
    I’ve got a van full of n case nine inches.
    Bones
    Speed Gems likes this.
  13. Speed Gems
    Speed Gems
    @Boneyard51 The "N" cast into those 3rd members means Nodular iron and the high performance drag/circle track etc. guy like those because it's better iron, still a casting but made of better material. There is one rear end that is build with the "N" cast inside with a part number i can't remember as well.
    Boneyard51 likes this.
  14. Boneyard51
    Boneyard51
    Yep, I haunted the salvage yards and kept an eye out for them. At my local salvage yard all rear ends were $50 each. The odd thing I found out was that Ford sprinkled them wille-nillie . The big 460/400 cubic inch pickups, never had them. But you find a 302 powered Sport pickup, you were almost guaranteed an N case, 3:50 traction loc. I got everyone I could find. Plus some 44 s and 60 s.
    I guess I’m just a “ rear end” kinda guy! Lol
    Bones
    RICH B and Speed Gems like this.
  15. squirrel
    8 3/4 " rear is a 9" with a slightly smaller ring gear, used in the mid 60s in Falcons, Mustangs etc? There is reference in the 1965 Ford compact/midsize shop manual.
  16. Working at a Ford dealer in those years I remember doing a lot of dealer installs of limited slip on the 9" rear ends. The half tons with factory limited slip had integral(Dana) rear ends from the factory.
  17. Boneyard51
    Boneyard51
    Not sure of the years you are talking about, but Ford pick ups in the late sixties and throughout the seventies also had traction enhancers in the nine inch from the factory. The 250s all had Dana’s with or with out traction enhancers. You may notice I use the word traction enhancers. The reason if you use the words” limited slip “ or “track-loc “ or “ posi- trac” etc. everybody starts disagreeing with you! Most of the traction enhanced rear ends Ford put out , we’re some sort of clutch type rear end. If you got a “ Detroit locker” in a Ford, sometimes it was marketed under “ no spin”. Over the years Ford offered a lot of stuff under different names.
    Bones
  18. squirrel
    Ford used the Dana 60 in the 60s in half ton pickups, also...I have two of them....5 lug, 3.54 ratio, limited slip.
    1Nimrod, Boneyard51 and Speed Gems like this.
  19. Boneyard51
    Boneyard51
    Just like the “ one “ I have, I mentioned in post 12.......and you have two! Lol They are beast, not unlike the rear ends of the high powered MoPars.
    Ford also offered the traction enhanced rear ends in Dana 44 and Dana 70 during the sixties.
    Bones
    1Nimrod likes this.
  20. squirrel
    GMC also used both the 44 and 60 in half ton pickups
  21. My 66 GMC has a dana 44. Yep a no spin is a entire different animal than a posi track or any clutch type rear. I owned a ot Z28 Camaro with a 12 bolt posi. someone had filled it with 90 weight gear oil instead of Gm posi lube. and it became a one wheeler.
  22. Boneyard51
    Boneyard51
    Clutch type traction enhancers in rear ends have a limited life time, determined by use. Even a “ wore out” clutch type rear end is better than an open rear end for traction, by how much, depends on wear and conditions.
    If you take a brand new clutch type traction enhanced rear end and put one tire on grass and one tire on pavement and pop the clutch..... the grass tire is going to spin! In order for them to work, both tires have to have somewhat similar traction, not exactly the same, but close.
    A Detroit Locker, No Spin, a few other types are a different story.
    Bones
    1Nimrod likes this.
  23. 52lomofo
    52lomofo
    Would that 2.50 center fit in another housing from 57-72??
  24. Well at least the chopped up finger hasn't affected you keyboard skills. I weld the spyder gears on a open rear. then remove the splines from the drivers side axle. you get a open rear. and when needed you install a splined axle and have a spool.
  25. squirrel
    the center should fit in any 9" housing from 57-86. The pinion yoke and axle spline count might be different, so you do have to consider that. Also some rears had a fill plug on the housing, not the center section, so pay attention to whether or not the center chunk has a fill plug, and whether or not it needs one.
    1Nimrod likes this.
  26. Boneyard51
    Boneyard51
    Well I’m 10% slower! We called those “ Lincoln Lockers”!
    Bones
    1Nimrod likes this.
  27. Ive had to put the rear end lube in thru the axle housing cause of no fill plug.
  28. I installed a used dodge flathead six in a pickup. had to use a oil pan without a dip stick and a block that did not have a dipstick. No way to check the oil. So I just put 5 quarts in it. The guy who owned it was from Eastern Kentucky . He came and picked it up and drove away headed home. I often wonder about when he stopped to get gas and check the oil?
