Technical Ford 8" limited slip ID
Discussion in 'The Hokey Ass Message Board' started by Scott, Jul 17, 2019.
  1. Scott
    Scott
    Can you Identify if this is an open vs limited slip at a glance
  2. squirrel
    sure, if I were able to glance into the axle holes, and see if the side gears are one piece or two pieces (the second piece is the hub for the clutch)
  3. doyoulikesleds
    doyoulikesleds
  4. big john d
    big john d
    from ma
    is that carrier for that housing? the bearing in the second picture does not look pressed on al;l the way
  5. I’m with squirrel, can’t tell from those pictures
  6. Jalopy Joker
    Jalopy Joker
  7. Relic Stew
    Relic Stew
    from Wisconsin
    On a 9" Trac-Lok the ring gear bolts are recessed into the clutch cover. I think the 8" is the same.
    Yours looks like an open.
    By the way, the Ford 9/8" clutch type limited slips suck because there isn't room for a proper pair of clutch packs. They just get a few disks on one axle shaft that wear rapidly.
  8. Not sure if this helps, but this is the Auburn Locker I put in the 8" in my Model A Auburnfor8in.jpg
  9. squirrel
    It helps one way...we now know it's not one of those.
  10. Scott
    Scott
    I think its open.
    squirrel likes this.
  11. Scott
    Scott
    Id like to try an Eaton Tru Trac if I can afford it
