Ford 8" axle ID
Discussion in 'The Hokey Ass Message Board' started by Crafty, Aug 17, 2010.
  1. Crafty
    Crafty
    from UK
    I've got an 8" axle here from (I think) a mustangII, I want to positively ID it, but annoyingly the data tag has been snapped off.
    Its 57" face to face.
    In the diff casing I see 5M17 cast in small letters and 19 in larger letters just to the right of that.
    Up near the yoke the I see "DW20 D" stamped and 315 cast in to it a couple of inches away.
    Did a search but all I find is data tag info.
    thanks!
  2. mustangsix
    mustangsix
    Mustang II will be a 4 x 4.25" bolt pattern.
  3. Crafty
    Crafty
    from UK
    Yeah it is 4 stud.
    It appears to be a LSD / posi or whatever ford called them, hence wanting to ID it for sure.
  4. johnnie
    johnnie
    from indiana
    Those casting #s won't tell ya anything about what is inside. That is why it has a tag. Gotta get in there if the tag is gone! Pull the drivers side axle and look at the splines. Most of the time, you can see a line dividing the wear mark on the end of the axle if it is a Traction Lock.
    Broken spiders, and some other things, can make it lock up and appear to be a Traction Lock.
