Technical Ford(?) 3speed manual transmission ID
Discussion in 'The Hokey Ass Message Board' started by ventilo, Jun 2, 2014.
  1. ventilo
    ventilo
    Hello,
    a friend of mine aquired this Ford(?) 3sp transmission with a bunch of flathead parts. We were unable to locate any marking on the transmission and would like to know what exactly we've got.
    Since some of the parts originated from Eastern Germany there is a chance that it is a GAZ transmission.
    WP_20140531_13_15_43_Pro.jpg WP_20140531_13_15_53_Pro.jpg WP_20140531_13_16_05_Pro.jpg
  2. Open it up and look but I doubt it's a 39. I say that looking at the leaning top. I believe that says 36 if I remember right. Top center of the bell housing on the flat spot is the i.d. numbers to tell you exctly what it started life as, that still don't mean much. Open the top and look.
    The Wizzard
    ventilo likes this.
  3. 117harv
    117harv
  4. alchemy
    alchemy
  5. Bruce Lancaster
    Bruce Lancaster
    ventilo likes this.
  6. ventilo
    ventilo
    Thanks, will have a closer look for the numbers. Good to know its a Ford flathead transmission anyway.
  7. Mac VP
    Mac VP
    Appears to be a 35 based on the rear mount and the slanted shift tower. Would have straight cut teeth on the low / reverse gears. Seems to have an odd hub for the clutch release bearing.
    ventilo likes this.
