ford 302 in 1955 ford
Discussion in 'The Hokey Ass Message Board' started by 1955ford, Aug 12, 2005.
  1. 1955ford
    1955ford
    from so-cal
    I am get done building my 302 with c4. The old staight 6 is out and I was woundering if someone has done this swap and can give some advise on fabbing up some motor mounts or if some company sells a kit.
  2. chopndrop
    chopndrop
  3. chopndrop
    chopndrop
  4. Crusty Nut
    Crusty Nut
    I am working on a friends '56 ford. It was originally a 6 car and the 302 we are using is out of an 80's mustang. I found that by swapping the 302's motor mounts left for right and slotting the holes on the car's crossmember the motor drops right in. We are using a T-5 tranny and the stock crossmember only needed minor hacking as well
  5. carkiller
    carkiller
    I used the 79 capri/mustang V8 mounts and as said left ta right right ta left inlarged hole in frame and bolted in W/Granada 4 speed, No crossmember or driveshaft work
    Kustomline54 likes this.
