Technical Ford 302 87te roller motor, going back to flat tappet
Discussion in 'The Hokey Ass Message Board' started by Ryan756, Jan 19, 2016.
  1. Ryan756
    Ryan756
    hi, ive got a ford 302 short block out of a 80's truck. engine number 87te or e7te, hard to read casting. it is a roller motor with roller lifters/cam/spider plate/dog bones. what i want to do is convert back to a flat tappet setup. what is the steps to do this properly? i have read that all will work fine if i just put my flat cam/lifters in, plug the holes in the block where the spider bracket had held down the roller lifters, and get longer pushrods? what length pushrods (the size i would normally use with a flat tappet setup)? i also read that oil passages on the lifters need to be taken into consideration because of the taller lifter bores on the roller block. what type/size/length lifter do i need in order to ensure that i dont run into any oiling problems there? can you give any insight or info on how to get my flat tappet equipment back in this roller motor?
    also i wanted to ask since i am writing this. i have my eyes set on a big mutha thumpr series camshafts. it is part# 31-603-5 and grind# 295TH7. will this cam work with my 302? The pistons are aftermarket and fly cut for more clearance, part# h273cp. aluminum heads will be properly springed and setup for it as well. i just want to make sure i wont have any piston to valve clearance issues. whats the max lift cam i can run with this block i have?
    any help would be greatly appreciated on this. thanks so much.
    -Ryan
  2. Jalopy Joker
    Jalopy Joker
    and the reason for this is? what is motor going in?
  3. Why would you want to remove a roller and go flat tappet? That's a backwards step in terms of performance unless all you're after is the lumpy idle.
    As far as converting, you'll probably need to change the distributor gear and you'll need longer pushrods. How long will depend on the type rockers you're using. Piston to valve clearance? Ask the cam manufacturer, and if it's close you'll need to measure it....
  4. Ryan756
    Ryan756
    Your right. Iam after the lumpy idle. I know the differences i just want to go flat tappet. Can this be done? How about the lifters oil holes and the galleys in the motor? Taller lifter bores and they wont line up. Is there a special lifter or what
  5. Ford used the roller blocks for flat tappet motors in some OEM applications and as far as I know you simply use the 'standard' flat tappet stuff....
  6. Ryan756
    Ryan756
    Its goin in a 64 falcon. Anymore insight? Only thing im concerned with at this point are the bosses the lifters go in.
  7. seb fontana
    seb fontana
    from ct
    Can't get the Thumpers in roller? I haven't looked but got to be out there..
  8. AHotRod
    AHotRod
    You better have the piston-to-valve clearance measured before you do anything, and then the valve spring pressure must be measured on the seat and at open of what the lift will be, you could be into valve spring bind.
    You will need .150" longer pushrods, and adjustable rocker arms, and the spring seats will have to be machined larger to accept the appropriate valve springs to control the camshaft.
    Comp makes the Thumper Camshafts for the Ford 302 Roller Cam Engines http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1528&sb=2
  9. Ryan756
    Ryan756
    I appreciate your time and response. Do u have any info on the tappet lifters in the bosses not drawing oil because the bosses are taller on the rollers. Hole on the side of the lifter is what iam talking about. Needs to line up with the galley in the block to get oiled
  10. sunbeam
    sunbeam
    Put a E303 cam in it and enjoy the ride.
  11. AHotRod
    AHotRod
  12. Diavolo
    Diavolo
    I'm trying to not knock your ambition, but going away from roller if the block is already designed for it is the wrong way to go. The benefits far outweigh any change back in tech. You can definitely get the sound you want with a roller cam, even more so. The lumpy idle is a result of degrees of valve overlap and if you can't buy it off the shelf, I am sure someone out there will custom grind one for you. As a reference, the cam you selected is 107 degrees lobe separation and less lopey cams run around 110 degrees.
    Also, this is probably going to get flagged soon so... good luck!
  13. Mike51Merc
    Mike51Merc
    I wouldn't do it. Too many roller benefits.
  14. NewGuyOldFord
    NewGuyOldFord
    I have a 306 roller motor with the "as mentioned" E303 cam and it idled and shook the windows. I also have a GT40P motor with a TFS stage II cam in it and that rattles about everything in the car at idle.
