Technical Ford 300 six
Discussion in 'The Hokey Ass Message Board' started by Karl_William, Nov 29, 2021.
  1. Karl_William
    Karl_William
    How much power can the bottom end take assuming ARP fasteners used?
  2. RmK57
    RmK57
    500+ hp with stock rods and crank.
  3. Karl_William
    Karl_William
    Wow
    Spooky likes this.
  4. Karl_William
    Karl_William
  5. RmK57
    RmK57
    There's a buildup, dyno run video on a 300 six on Power Nation. Impressive numbers for sure.
  6. oldiron 440
    oldiron 440
    You can turn em till just before they break.
    rladams65, 55willys, fauj and 8 others like this.
  7. Boneyard51
    Boneyard51
    A bunch of horsepower!
    Bones
    Joe Travers and Karl_William like this.
  8. Casey Riley
    Casey Riley
    from Minnesota
    If I remember right it, had an entirely custom made one off head...
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    My avatar car makes about 550 HP at the crank. Has run 9.00 @ 147 mph quarters. It has a forged crank, crossflow head, billet rods and forged 13.4:1pistons. I've raced the same combo for years, limiting the revs to 7000 RPM.
    Another less radical RPU drag truck I have has a stock bottom end but with a big valve head and 10:1 compression. We limit that engine to 5500 RPMs and have almost 1400 passes on it without failure.
    Are you planning a build for the street or for some type of competition?
    www.fordsix.com has all the info you'll need.
  10. Seven main bearings. Genius.
    tomkelly88 and Spooky like this.
  11. 41rodderz
    41rodderz
    from Oregon
    I was going to say, Frenchtownflyer is your man. I never did dyno runs but I had a 300 six with 4.88 lift cam , duals , Offenhauser intake and 390 cfm Holley .
  12. Brian Penrod
    Brian Penrod
    Thank you for the website, just joined. Thinking of using a 300 six in a 23 T altered, just to be different.
    Truckdoctor Andy likes this.
  13. Greatest In-line gasoline six cylinder ever built, hands down.
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
    Nearly unbreakable torque monster !
    VANDENPLAS likes this.
  15. Karl_William
    Karl_William
    A sleeper would be nice, possibly my Falcon. I'd like it to embarrass these dodge chargers and the like that act all tough when they pass my other Ford POS.
    Cooon and fourspd2quad like this.
  16. RmK57
    RmK57
    The 250-300 sixes are quite a bit longer and taller than the 170-200 sixes. Not sure how you could squeeze one in an early Falcon.
  17. FrozenMerc
    FrozenMerc
    Rule #1: There is ALWAYS someone faster than you. This is why you don't wrestle with pigs in the mud. At some point you realize the pig likes it.
    That said, building a fast and powerful 300 follows the same rules as any other engine. You need to get more air and more fuel into it during each stroke. One of the most efficient ways to do that is with a turbo. 300's respond very well to forced induction.
    ratrodrodder, mgtstumpy, fauj and 2 others like this.
  18. Karl_William
    Karl_William
    People been putting big blocks in em for ages, I'm sure another 6 will fit.... somehow.
    Hnstray and VANDENPLAS like this.
  19. Karl_William
    Karl_William
    I'll check out that vid when my highspeed data is better! Wouldn't nitrous be more efficient than any mechanical power adder?
  20. 51504bat
    51504bat
    When I worked as a mechanic at a dairy in the mid '70's all of the DIVCO milk trucks had been converted to 300 6's. The delivery drivers could break almost anything but not the 300. Good engines.
  21. RmK57
    RmK57
    This would be a fantastic engine in 57-60 F-100. I like it!
    Hnstray likes this.
  22. finn
    finn
    The 250 is part of the 144/170/200 small six family, albeit with a taller deck to accommodate a longer stroke crankshaft.
    The junior brother to the 300 is the 240. The large six has a greater bore spacing than tha small six family, so it’s longer.
    Hnstray and Boneyard51 like this.
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Different? YES. The first? Nope
    Before I had six cylinder altereds I had a '64 Falcon Sprint I put a 240 big six in with a 4-speed toploader. I think I moved the radiator in front of the horse collar. My favorite targets were '60s Corvettes.
    A V8 has its accessories mounted ahead of the heads. An inline six has the accessories mounted on the side of the heads.
  24. Karl_William
    Karl_William
    Got any underhood pics of the falcon?
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    No, I unfortunately do not think so. But it was a really bare bones build up - head work, flat tappet cam, 600 4V carb on an Offy intake and headers. Oh, and a straight axle. I was unemployed at the time of the build and the entire investment in the engine was $700. The secret sauce was I used lots of fiberglass - front end, doors, deck lid, bumpers. It weighed 2510 lbs with me in it. That car cemented my desire to run Ford sixes for the rest of my life. The altereds came later, when I was more financially sound.
  26. Karl_William
    Karl_William
    I been looking at them Clifford dual setups. Comp has what seems to be a decent "street/strip" cam kit. Schneider has some fairly wicked cams too. I would think the heads would be the real limiting factor to these engine. I know Promaxx makes a decent CNC iron head. I've heard of these aluminum cross flow jobs, but they don't seem to exist. Not in the commercial market anyhow. Should I even be concerned about the head for a street build?
  27. gimpyshotrods
    gimpyshotrods
    It has been done, but it requires MAJOR surgery to the firewall, and the hood.
  28. gimpyshotrods
    gimpyshotrods
    Yup. I have a 200 in my '60.
    If I want to take my fan off, the radiator has to be removed first. It's that tight.
  29. Ebbsspeed
    Ebbsspeed
    I love seeing some of the stuff in the background of photos.
    Here's a fella workin' hard at the starting line.....
  30. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I absolutely love the 2 x 2 Clifford for street and street/strip applications and think it has advantages over a 4V. The Autolite2V carb is vastly superior to other popular brands for several reasons and they are a fraction of the cost.
    Don't rule out making your own multi carb intake either.
    I am not convinced the Promaxx head is superior to Ford castings. I think a rebuilt Ford head will do just fine. The pre '87 head or the 240 head would be good choices for your build.
    2x2 intake 01.jpg 41521538261_56df79d702_n.jpg willys01.jpg Clifford 2 x 2 04.jpg int3x109.JPG
    In addition to the Falcon, I raced a 300 Pinto built by my friend Pete with my help. pinto2.jpg
    Did you notice the cowl section on the Pinto was disappeared to make room for the big six? It was added on to the back of the hood.
