ford 289 - best carb for it?
Discussion in 'The Hokey Ass Message Board' started by billj, Aug 21, 2011.
  1. billj
    billj
    I have a Motorcraft 2 brl on it that is rebuilt that I was told is a real good carb. I just can't seem to get it to stop from running rich and will continue working on it but was wondering if anyone has ideas on this and what has worked well.
    I just want a good dependable carb that is responsive but not a gas guzzler.
    Thanks,Bill
  2. mustang6147
    mustang6147
    from Kent, Ohio
    Honestly they are all good when they are right. You probably need a rebuild or a re cleaning.
    I had an autozone fuel fitler issue where the glue was braking down and not letting my needle and seat, seat properly
    I would stay around 450 or 500 cfm's and if you go Holley, go vacuum secondary
  3. Cerberus
    Cerberus
    Holley has a 2300 series 2 bbl. It has a maual choke. Comes in 300 cfm and 500 cfm. I'd go with the 500 cfm. Summit carries them for less the $285.00
  4. Deuce Daddy Don
    Deuce Daddy Don
    Go with the Holley 500 cfm off road type----Good reliable, good milege,& not a double pumper, manual choke.
  5. 49ratfink
    49ratfink
    I put a 390 4bbl on my old Mustang.
  6. Deuces
    Deuces
    I have a stock Holley carb for one of those..
  7. 65COMET
    65COMET
    One thing that a four barrel manifold and carb will do is give you a more even distribution of air/fuel across the cylinders.You may even pick up mileage,if you stay out of the secondaries!The vacuum secondary style carbs work great on the street,I've used both the Edelbrock 500 cfm and the various small Holley 500 cfm carbs with great success.I'm currently running a Holley Avenger,600cfm on a mostly stock 302,works great. ROY.
  8. MERC 55
    MERC 55
    Nothing wrong with Motocraft
  9. billj
    billj
    Lots of options.
  10. MeanGene427
    MeanGene427
    from Napa
    If you just want sweet running and mileage, it's very hard to beat the old Autolite 4100- or even a 4300 if you run across one. Very nice idle and clean running, and dependable as a rock
  11. Ford-Man
    Ford-Man
    Autolite 4100.
  12. willymakeit
    willymakeit
    I will be the 3rd one to recommend the Autolite. Check Pony carb.?
  13. Ford-Man
    Ford-Man
    Screw Pony Carb...they cost WAY too much. Look at local swap meets. I scored both of mine for a grand drum roll worthy total of $75...and one of em came off a running car. Both are 600 CFM.
    They are still out there and quite abundant. The hard part is finding one with the exact carb tag that matches the build of your Stang or Galaxie. Outside of that, common ones without tags should be relatively inexpensive.
  14. billj
    billj
    I will look for a 4100 while i f*ck with my carb I have. Thanks, Bill
  15. snaptwo
    snaptwo
    depending on what you expect of that 289 , you probably have the best carb. in that little autolite/motocraft. Check the power valve as that can really cause a big time fat condition. If the 4 bbl. sounds better, the 4100 series is hard to beat but they are getting scarce. Stay around 450-500 cfm max . I have a 67 bronco with the stock 289 and an Autolite , works great in all off camber off roading and has for the last 35 years weve owned it.
  16. 63bigbird
    63bigbird
    I have an Autolite 4100 that came off a 63 390 if interested. 75.00 worked when I took it off.
  17. Red Dragon Racing
    Red Dragon Racing
    from Indiana
    4100's are great. I believe the 1.08 ven is the 480cfm which was the standard 289 4bbl and the 1.12 ven was the 600cfm which came on the hi-po motor.
