Technical Ford 223 Issues
Discussion in 'The Hokey Ass Message Board' started by 58Darlene, Jun 22, 2015.
  1. 58Darlene
    58Darlene
    Need a little help here. Started having an issue with the ole 223. It seems to start and run pretty well for a few miles, then starts to choke and stutter. The timing is right, the vent line from the tank is clear, and I put on a spacer to isolate the carb for heat. maybe there is something simple I'm missing.
  2. Vacuum leak,plug wires good?
  3. 58Darlene
    58Darlene
    Plug wires are good, and I don't think there's a vac leak anywhere
  4. ev88f
    ev88f
    Condenser? Sometimes when they go, they can act up once the engine gets some heat in it.
