The most Powerful Naturally aspirated Y-Block in History. Own Jon Kaase’s Y-Block that won his 6th Engine Master’s Challenge. 400 Cubic Inches 550- 700 HP, depending on cam Specs: • 1961 292” Ford Y-Block Block • Kaase custom steel Main Caps • Kaase custom main girdle • Diamond Pistons 13.5:1 Compression 3.87” bore • Trend DLC coated wrist pins • Total Seal Rings • Carillo rods with CARR bolts • Bryant Billet 4.250” crankshaft • King main bearings • Clevite rod bearings • Durabond cam bearings • Edelbrock 7110 Tunnel Ram intake • Trend pushrods • Trend tool steel lifters • Comp custom flat tappet camshaft • Rollmaster timing set • WW Engineering rockers • Mummert Cylinder heads (custom Kaase port design) o CHE valve guides o Xldyne Seats o Ferrea valves o Comp Springs • MSD Distributor • MSD Spark Plug wires • MSD Crank Trigger • Cometic Head gaskets, FelPro valve cover gaskets • Innovators West balancer • Moroso custom oil pan • Melling oil pump • ARP Drive Rod • Meziere electric water pump (770) 307-0241
