For Sale: 1963 Dodge 330 Super Stock Clone
Discussion in 'Cars For Sale' started by Byron Crump, May 14, 2017.
  1. Byron Crump
    Byron Crump
    City: Flower Mound
    State: TEXAS!
    Price: $37,500.00
    I bought this car several years ago and have done minor changes.
    Car was feature in Car Craft back in 2003 before I owned it.
    Link to article on Hot Rod Magazines page to the article:
    http://www.hotrod.com/articles/ccrp-0308-1963-dodge-330/
    Motor/Car Info:
    1963 Dodge 330
    Engine is a 440: 30 over 1970 HP block
    Steel crank
    LY Rods
    JE lightweight forged piston, 10.5 compression (runs on pump gas)
    Block drilled for 1/2-inch oil pick-up
    Milidon 7 qt oil pan
    Lightweight starter
    906 ported and polished heads
    2.14 intake valves (2.08 stock) and 1.81 exhaust valves (1.74 stock)
    Crane 1.5 roller rocker arms
    Cammonics roller cam: 292 duration with .540 lift
    Comp cams roller lifters
    MSD billet distributor
    Crane Hi 6 ignition
    Milidon true roller timing chain
    Mopar M-1 single plane intake
    750 Edelbrock carb
    Doug’s 2" primary headers Jet Hot coated
    3" aluminized exhaust
    3-chamber flow master
    Big yoke drive shaft
    727 trans with slip yoke tail shaft
    Pushbutton shifter
    Continental 10" 3200 stall converter
    1965 8 3/4 rear end with sure grip
    489 case with 430 gears
    Super Stock rear suspension
    Frame connectors
    Drive shaft loop
    6 cylinder torsion bars
    American Racing TTO’s
    Trunk mounted battery
    Base coat clear coat black paint on super straight body
    Be-Cool aluminum radiator with duel electric fans
    High flow water pump and thermostat
    Front disc brakes with dual master cylinder
    Rust free California car.
    Front grill and headlight rings are chromed.
    Original taillights.
    All the trim is on it, and that stuff is very hard to find.
    Moon red metal flake steering wheel, I have the original wheel.
    Sun reproduction tachometer (They don’t make that anymore!)
    Seen in Aug 2003 Car Craft magazine
    Best of show 2003 Sacramento Mopar show
    Located in Flower Mound, Texas.
    $37,500.00
    Todd553, RDE and grichards790 like this.
  2. Byron Crump
    Byron Crump
    Bump
    I would consider trades of 1971-72 Road Runners that are numbers matching, 1939-40 Ford Coupes, or real steel Model A Roadsters (on deuce rails with cool mills…sorry, no Brookville’s) etc. of equivalent value or with a bit of money tossed in if not of equal value.
  3. Byron Crump
    Byron Crump
