Parts included: · 1931 all steel Tudor Sedan – Not chopped, sandblasted. Needs minor patch panels finish welded. With Steadfast subframe kit (installed). Illinois Title in my name. · All new wood kit · New all steel 30-31 Firewall · 1932 Steel grill shell · 1932 Steel dashboard · New aluminum radiator and new Spahl electric fan · Blackboard Hot Rods custom deuce chassis pinched, 3” sweep, notched front and rear, bobbed rear set up for transverse spring. · Complete Pete and Jakes front suspension with hairpins and dropped Super Bell front axle. · Complete Pete and Jakes ladder bar rear suspension with transverse spring · Vega cross steer with new Vega steering box · Limeworks polished steering column with new Banjo steering wheel · New Currie 9” rear end with new Posi Traction 31 spline center section (3.73 gear ratio) · Pete and Jakes Disc brakes in front and new 9” drum brakes in the rear · Brake master cylinder (manual) with complete brake line kit · 750R16 Excelsior Sport Radials (rear) mounted on new 16x6 Steel Wheels (black powdercoat) · 550R16 Excelsior Sport Radials (front) mounted on new 16x4 Steel Wheels (black powdercoat) · Tanks universal 14 gallon gas tank · New Guide 682-c headlights and new 1937 Ford tailights w/mounting kit · New Optima Battery · 292 Ford Y-Block .030 over, .10/.10 crank. Completely rebuilt with 1958 ECZ-G cylinder heads and new Ram horn headers. All machine work done by FastTimes Motorworks. · Rebuilt Ford AOD automatic transmission with new torque converter, Limeworks column shifter and AOD transmission adapter kit including new flywheel and high torque starter · New Denny driveshaft All the heavy fabrication work has been completed and all major parts pre-fit. Selling for $23K. Pick up only or arrange shipping at your cost. Located in Vernon Hills, IL
