""Fools rush in to the"" Aprill 2013 Banger Meet
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Apr 1, 2013.
  1. Bluto
    Bluto
  2. winduptoy
    winduptoy
    Crazydaddyo
    Sounds really nice with the cam lope and megaphone exhaust. I like, I like, I really like, but I think you are going to have a rough ride on those little bitty steel front wheels with no rubber. It does get it low...
    LJ
  3. Crazydaddyo
    Crazydaddyo
    With all the power this new engine will put out, the front wheels will never be on the ground. :D;)
  4. Crazydaddyo
    Crazydaddyo
  5. Crazydaddyo
    Crazydaddyo
  6. 4bangertroy
    4bangertroy
    from Phoenix
    Sounds great Dan!!
  7. Bluto
    Bluto
    Craze....... I collect stuff no one has ever seen. The machine allows me to build engines, bag, and store them till needed. Then spin them once more and install em......
  8. gemcityrenegade
    gemcityrenegade
    Got any engines for sale? Where are you? Ohio?
  9. V4F
    V4F
    from middle ca.
  10. Olderchild
    Olderchild
    from Ohio
    Such a tease crazy you could have burped that baby at least once:D
  11. Oh Yeah, I am sure it was burped more than once!!
    Sounds great Dan, are you bringing to Irwindale in June?
    John
  12. Crazydaddyo
    Crazydaddyo
    Thanks John,
    Definitely going to Irwindale!!!!!
  13. winduptoy
    winduptoy
    I know I wasn't thinking it through :confused: now that you point it out. That is why I wear bright.
    I got my Powergen today and since my best ideas are borrowed, and you have been through it once before, would you mind posting a close up of the mount that you built to get the V8 mounting on the Powergen adapted to the B engine unless it is patented or copywritten ?
    Had to listen to the engine one more time.
    LJ
  14. I'll be looking for ya!!
    Be carefull of the raceway safety requirements, rumor is change from last year.
    J
  15. Reddy
    Reddy
    Hi
    I was looking on ebay under "scta" and a 1932 Model B motor was on for sale
    but it have just 4 hole for the valves ?? it ends monday 9pm what's up with that
    Mike
  16. Carter
    Carter
    The holes were plugged. It had an F-head OHV on it, like a Roof or Riley.
  17. Crazydaddyo
    Crazydaddyo
    Here is the best I could do .
  18. winduptoy
    winduptoy
    Crazydaddyo,
    Perfect. Thanks I really appreciate it very many.
    LJ
  19. kirby1374
    kirby1374
    Please forgive me if this is a beginner question that does not belong here but; I will need to drop the oil pan on my 30 Tudor soon, the oil plug bung is spinning with the plug
    Anyway while the pan is off is there a way to check a pump other than install it and check it with a gauge? I am asking because I have an extra motor that I will be borrowing the pan from and while I'm doing this I thought if the pump from the donor motor is better then I would use that one.
    The pump I am currently using has 7lbs+ at startup then down to 2lbs when warm at a high idle and almost 0 on the gauge at idle when warm.
  20. V4F
    V4F
    from middle ca.
    the oil pressure is about normal . when the pan is off , check the center main for wear . ................... steve
  21. BCCHOPIT
    BCCHOPIT
    For the banger guys going to the HAMB BBQ I hope this set up makes it there in time.
    I shipped it out today so he should have time to bolt them one. Let me know how it sounds
  22. Crazydaddyo
    Crazydaddyo
    Looks good Bill. What did you use for filler rod on the cast iron?
    I'm interested to hear this set up. Is it going in a stock bodied car?
  23. V4F
    V4F
    from middle ca.
    always experimenting ! good looking set-up !!
  24. BCCHOPIT
    BCCHOPIT
    DaddyO
    T on a model A it will have a log style intake with my thick flanges to go with it.
    MG200 tig rod was used. They are both used repops one welded real nice the other busted my balls it couldn't take much heat ( junk cast steel) I hope they hold. They sat for a hour in the grill at 600 deg. They didn't crack when cooled. Wish me luck.
    I did a test set 2 years ago with some junk stock ford and they welded a little better but I could never run them because I fly cut them to get them flat and clamps hit my side cover. I should have started with nicer ones.
    I was told my car had a set up like this in 1956 and 7 but I never found them in the barn.
    Thanks Steve....
  25. Just about to pull the engine to hopefully solve the rear main leak - pressurised engine with a Burtz rear seal that wasn't fitted by me. Hey ho. If it leaks again THEN it's my fault!
    Thought I'd share a picture of the new carb arrangement. Still have a little plumbing to do but it ran lovely on one of these so why not try two...?
  26. Anyone have the details for the guys who provide the F150 trans conversions?
    Just working out either to go T5 with a crazydadyo adapter and then shorten the T-tube, or one of the F150 kits.
    I know Ken Parker does one that I saw in the SOSS recently, despite the write up saying 8-10 weeks order time, I got a reply saying sorry bigger priorities wait to Xmas!
    Thanks guys
  27. BCCHOPIT
    BCCHOPIT
    Can you use the 4 speed F150 with a T- Tube?
  28. Yes, There are some guys who provide the kits for the whole install, I just dont have their contact info hence the Q :)
  29. BCCHOPIT
    BCCHOPIT
    My 2 cents go with the 5 speed.
    The gear split in the f150 box is like stock 3 speed and I hate the stock gear split
