""Fools rush in to the"" Aprill 2013 Banger Meet
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Apr 1, 2013.
  1. Crazydaddyo
    Crazydaddyo
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.billsbangers.com
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculatorfin.jsp
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
  2. johnneilson
    johnneilson
    already??
    crap May is right around the bend, I better finish some assembly
  3. skryla
    skryla
    from Brick, NJ
    Anyone else have any comments about running a magneto versus distributor?
  4. Crazydaddyo
    Crazydaddyo
    Wrapped up my new engine this week end.
    I should have it in the car this week end.
  5. Bluto
    Bluto
    Your work always looks nice
  6. skryla
    skryla
    from Brick, NJ
    Great looking engine! Where did you get the oil filter set-up?
  7. modelAsteve
    modelAsteve
    What are using for a pad under the front motor mount?
  8. Love the thread! I really love the motor! I hope my motor can look as good.
  9. Crazydaddyo
    Crazydaddyo
    Thanks Jimski, Your opinion means a lot to me.
    The filter set up came from Taylor engine. 562-698-7231.
    The oil lines are normally hose, I did the steel lines because I like the look better.
    I use the Ford Flathead V-8 engine mount pads.
  10. Is that a B or A block Crazydaddyo?
    On another note I blew my first head gasket. Any recommendations for the best gasket to use?
  11. Like has been said before, the major problem with a magneto is there is no timing adjustment. I think I've seen special lead plates for the V8's that you could adjust it by on the fly. But I have never seen one for a banger.( not saying much there;) )
  12. Crazydaddyo
    Crazydaddyo
    It is a B.
    Where did the gasket fail?
    I use the copper sandwich gasket from Best.
  13. So the oil filter is on the fuel pump boss then? Looks like a cool setup.
    Best I can tell the gasket failed right up front at the water neck. It's pushing oil up thru one of the studs and spreading out over the head and it's got oil in the coolant and a little bit of water in the oil showing up in the filler neck.
    I haven't taken it apart yet, as I wanted to have a gasket first, but I will grab a couple pictures.
  14. Bluto
    Bluto
    About head gaskets:
    Pin the head and gasket so they stay in the correct position
    Use a countersink to ensure that the torqued bolts don't pull the hole's edge up
    I think Hylomar is the best sealer.
    http://www.youtube.com/watch?v=yXiVZIBoHL0
    Good luck
  15. Crazydaddyo
    Crazydaddyo
    Which grade of Hylomar do you use?
    Spray or tube?
  16. Bluto
    Bluto
    Industral grade. You can buy it in Gal can for what some want for a tube
  17. Crazydaddyo
    Crazydaddyo
    Is this the stuff?
  18. Crazydaddyo
    Crazydaddyo
  19. Bluto
    Bluto
    Craze......... look at the video I posted
    I don't really like spray cans too little too much $$$$$$$$
  20. Crazydaddyo
    Crazydaddyo
    Thanks Jim,
    Any issues with the sealant oozing out into the crankcase and clogging oil passages?
    It looks like it was developed for Rolls Royce and is used by a lot of race teams in NASCAR.
  21. Bluto
    Bluto
  22. Bluto
    Bluto
    This doesn't clog oil passages!!!!!
  23. Nice motor, will be pulling my Miller this week to try and sort a rear main oil leak!...
  24. So-Cal Speed Sacramento
    Alliance Vendor
    from Sacramento
    whose timing cover and mag drive is that?
    -rob
  25. winduptoy
    winduptoy
    Great lookin' banger.
    Looks like you are running a harmonic balancer, is that correct?
    Also, what is the generator? I really like the look. I need to kill the alternator on my banger it just doesn't look right.
    LJ
  26. Crazydaddyo
    Crazydaddyo
    The timing cover was a prototype by HAMB member Sawracer. He has since sold the patterns to this guy:
    The mag drive is from Norm Frick.
  27. Crazydaddyo
    Crazydaddyo
    Yes, that is a harmonic balancer.
    The generator is a powergen.
    http://www.powermastermotorsports.com/powergen.html
  28. winduptoy
    winduptoy
    Crazydaddyo,
    Thanks for the link on the powergen
    I recall seeing a post in last months banger meet that had dimensions for the balancer. One in the same?
    Thanks,
    LJ
  29. Crazydaddyo
    Crazydaddyo
    Yes, that is the one I made.
  30. What frame/car is this banger going in?
    Sent from my DROID device using the TJJ mobile app
