Foolin' with 4 Jugs...The April 2012 Banger Meet
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Apr 1, 2012.
  1. Crazydaddyo
    Crazydaddyo
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.billsbangers.com
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculatorfin.jsp
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
  2. Bluto
    Bluto
    Thanks Crazzzz I had no ''Title'' for April :)
  3. SPEEDBARRONS
    SPEEDBARRONS
    Speed
  4. V4F
    V4F
    from middle ca.
    jimski , never seen you without something to say . im moving to poland next door to you !!!!!!!!!!!!!!!!! APRIL FOOLS !
  5. New month same old stuff!
    Try this, Years ago I purchased a Winfield "Crows Foot" from an old lakes racer. He told me he had run 114 or something like that. He told me he had a Winfield Super Race cam. There are a lot of Winfield Super race cams. Just Google Winfield SU1A. Back in the day we spoke of 3/4 race, Full race, and Super, He said he had used 1 7/8" intake valves. Not sure if it was an A or B block but I'm leaning towards the A going with that large of a hole, although come to think of it, Geo Riley recommended opening up the exhaust with a 1 5/8" cutter in a B block. I'm about .060 .070 under that now in my A block. I will open it up to 1 5/8"
    So off to the valve box I went and found me a 2" intake and I turned it down to 1 7/8" Made a valve guide stuck it in an A block and dropped the current Winfield cast iron "crows Foot" on top of my thumb literally. This head has the numerals 8 6 88 stamped into the pad, measures about 110 cc's. No gasket and head has been milled .060. Well, not a lot of side clearance but with no gasket have around .450 over block at intake port. Cam has .365 lift with say .060 on the valve margin for total of .425 plus .060 for the head gasket. Almost forgot tappet clearance .014 would leave .099. Full 1.750 diameter intake valve just fits in the current Al repop chamber. Not sure if my math is right. So I think I'll try this combination and see if the flow comes from under the valve. Don't you re-engineers try to talk me out of it. Shrouding be damned. If you notice in the photo the valve pocket diameters appear to have been opened up. I have had 2 of these and they both looked identical in that area. Radius behind the valve is almost nonexistent.
  6. V4F
    V4F
    from middle ca.
    nice head . cams : i have an honest 3/4 cam ! isky on my wall !
  7. BCCHOPIT
    BCCHOPIT
    Don't waste that cam send it to me :D
  8. V4F
    V4F
    from middle ca.
    im not wasting it , im saving it as i promised . its an antique ! LOL
  9. Bluto
    Bluto
    You can buy that cam from Ed....... I Got one for our friend in Paris (France no Ohio) last year
  10. BCCHOPIT
    BCCHOPIT
    Do you have the specs if that 3/4 race cam?
  11. Bigcheese327
    Bigcheese327
    So the other cylinder is just... dead? Do you even put a piston and rod in the hole?
  12. <TABLE border=0 cellSpacing=0 cellPadding=6 width="100%"><TBODY><TR><TD style="BORDER-BOTTOM: 1px inset; BORDER-LEFT: 1px inset; BORDER-TOP: 1px inset; BORDER-RIGHT: 1px inset" class=alt2>Originally Posted by steve norcal [​IMG]
    i bought a nu-rex degree kit & marked my pulley @ tdc . works great , like a modern car . you can get the timing dead nutz .. steve
    **http://www.nurex.com/list_products.asp
    </TD></TR></TBODY></TABLE>
    "Steve; I tried ordering one but they won't sell to a Canadian :eek: I didn't realize that this company was so distrusting of "Outsiders".
    I gave Nu Rex a call late this afternoon and left a message. The owner called me this evening and apologized for not been able to get the timing kit on line and offered to send me one. He explained to me that they are more into the manufacturing of this kind of stuff and hardly ever sell direct to the internet customers. He did mention firms that do handle their products but as I said before he did offer to send me one. I declined his offer and placed my order for a timing kit with Snyders.
    Thanks to Steve and Herb for your offers to help.
    Ron
  13. Crazydaddyo
    Crazydaddyo
  14. Last edited: Apr 3, 2012
  15. I received the Secretes of Speed magazine today. They have an article about a Swedish made Split Cam. The cam can run !/4" higher lobes. The cam distributor oil pump gear is keyed and connects the two halfs together. A long bolt ties the two pieces together. The halfs are tilted into the engine and then the cam is assembled. The only comment was the cam lobes might hit a counterbalanced crank. The height of the lobes has been restricted in the old days because of the camshaft bearing diameters. I thought it was pretty neat.
  16. RichFox
    RichFox
    With the head bolted on and torqued. Valves adjusted. Just realized there is no oil drain back built into a Dodge bros. But it's getting closer.
  17. zenndog
    zenndog
    from Santa Cruz
    Some pics I took of Rich's engine yesterday
  18. RussTee
    RussTee
    What size are your oil lines Rich . Heaps of work there love seeing motors like this
  19. RichFox
    RichFox
    -10 to and from the pump. The 5 lines from the oil manifold to the mains are -4 teflon lined and hard line. If I ever tear the engine down I will put the oil manifold inside the pan and go to -6
  20. RussTee
    RussTee
    Thanks Rich It is a very interesting motor I always think the bigger the lines the better, I would agree with the oil manifold in the pan always a good way to go.
  21. Bluto
    Bluto
    Rich
    Teflon doesn't like heat..... you may have a problem with hot oil and teflon
    And I agree your always better off large lines unless the run is very short
  22. RichFox
    RichFox
    As compared to Earl's or similar rubber lines with stainless covers I trust Teflon more. We sure used a lot more of it on aircraft that I was around than the rubber. The whole oiling system on the Dodge is a big learning process. Wish me luck.
  23. Bluto
    Bluto
    I all wish the best for you Rich
    Please look up the max temps for rubber and teflon
    Teflon is higher pressure but not operating temps
    Size is a question of delta-p...... that is pressure loss over distance
    It's not the diameter of the hose but its area inside. This works both ways up and down.
    In a perfect world where you could test often without damage things would be less hit and miss.
    In this world I would rather have hoses large and a real high output pump
    I can tell you that in all the engines over all these years I only got the lines too large once....
    And over all these years I've looked at guys we raced against err to the too small and watched stuff die way too often.
  24. noboD
    noboD
    Rich, weren't these heads spritz and drive are far as oil goes? How are you going to fix it?
  25. RichFox
    RichFox
    Since i had no rocker assembly to start with I made my own and run oil through the rear valve cover hold down stud/-4 an fitting to the rocker shaft and to the Rocker Arm Specialty's rockers. The oil will drain back down the ex valve guides now push rod holes to the lifter gallery. Which I just now put a -6 AN line in that drains the gallery into the gear box for the distributer drive and back to the pan. I don't expect oil temps to be high enough to harm the Teflon lined hoses without being disastrous for some of the rotating parts. Check back with me after World of Speed for real world experience.
  26. Pierre H
    Pierre H
    from france
    Ho yes ! thanks again Bluto !
    Best thing was to bring the cams from Paris to Gardena !
    Please say Hi to Master Ed !
  27. Bluto
    Bluto
    I hope your using Airquip hose. Their website will tell you temp ranges Long time ago I learned I knew nothing and therefore assumed nothing..... I always look both ways before crossing the street....... and slide into first on ball four :)
  28. RussTee
    RussTee
    I have found that if an oil line is too narrow the heat goes up very fast. I like big braided lines with good fittings I know they are pricy but so is a new motor.
  29. 97
    97
    Hey guys Rustee was having trouble putting pics of his T up here so I am doing it for him. I will let Rustee tell you about them.
  30. RussTee
    RussTee
    This is my roadster pickup in pretty much its sidevalve version it is currently undergoing a rebuild with Rutherford overhead , winfield carbs , overdrive , quickchange and one of Pats wonderful front plates and dizy drives. I have driven this car for about 40 years.
