Projects Flywheel
Discussion in 'Traditional Customs' started by Desoto1949, Oct 1, 2017.
  1. Desoto1949
    Desoto1949
    Does anyone know where I can buy a flywheel for a 1949 Desoto
  2. steinauge
    steinauge
    from 1960
    Likely from someone on this board.Try posting in "parts wanted" in the classifieds.
    Desoto1949 likes this.
  3. Hnstray
    Hnstray
    from Quincy, IL
    Is it a manual trans car or a Fluid Drive? If manual, there are, no doubt, several Plymouth and Dodge flywheels that will work. Not necessary to locate specifically a '49 DeSoto' flywheel.
    Ray
  4. Desoto1949
    Desoto1949
    Semi automatic
  5. 302GMC
    302GMC
    from Idaho
    '49-'54 Dodge and Chrysler use the same flywheel ...
  6. 73RR
    73RR
    What is the 'need'?
    All pre-62 flywheels, L4, L6, (some) L8 and V8 have the same mounting configuration with a variety of 4-6-or 8 attaching bolts. The Plymouth, US models 201-208-218, have a different crank flange position so that flywheel is 'special' and can be problematic on other engines. There is also the choice of 146 and 172 tooth ring gears. New, truck weight, flywheels are available from Vintage Power Wagons and used flywheels are everywhere. With a flange adapter, you can even use a 130 tooth 426Hemi flywheel.
  7. d2_willys
    d2_willys
    from Kansas
    At the local Desoto dealer if one exists.
  8. 58prostreet
    58prostreet
  9. Desoto1949
    Desoto1949
    I just need a replacement because when I try to turn the car on it would make a loud scratching noise and plus the some teeth are chipped from the flywheel
  10. plym_46
    plym_46
    from central NY
    You can have a machine shop flip the ring gear. This exposes the unworn portion of the ring gear teeth to the starter gear. I did mine 40 k miles ago and never had an issue. Some will say that the teeth when flipped lach a beveled approach but it never became a concern.
    Hnstray likes this.
