Projects "Fly'nBrian" '34 Roadsterproject.
Discussion in 'Traditional Hot Rods' started by flynbrian48, Apr 28, 2016.
  1. flynbrian48
    flynbrian48
    Now, blast the bottom of the frame, then prime, prep, paint, and start putting things together.
    oldsjoe, waxhead and 36 ROKIT like this.
  2. flynbrian48
    flynbrian48
    ImageUploadedByH.A.M.B.1484332927.100642.jpg ImageUploadedByH.A.M.B.1484332942.484299.jpg ImageUploadedByH.A.M.B.1484333141.717166.jpg ImageUploadedByH.A.M.B.1484333174.084231.jpg
    Continued slow but steady progress on the roadster. I have an original dash that I kinda like as opposed to the one in it with too many holes. Which to use? I intended to do a stainless Auburn style panel for the hot rod-y one, and have a Police speedo...
    kidcampbell71 likes this.
  3. alchemy
    alchemy
    I like LOTS of Stewart-Warners, so either dash with a ton of gauges works for me. And the Police Speedo is even better. Maybe it's easier to arrange neatly on the simple dash?
  4. oldsjoe
    oldsjoe
    Not that it matter's or counts but I like the top dash small tach on the left and a large speedo on the right of the column. But hell what do I know! Joe
  5. flynbrian48
    flynbrian48
    Todays project(s) went pretty well. First off, I blasted the '55 Chevy rear end. Of course, I ran out of sand, and had to make trip to the hardware store for more, my usual MO. As long as I was out buying stuff, I went to O'Reilleys and got a gallon of polyester resin, some mat, and started gluing in the recess for the 283's distributor. I haven't glassed it yet, but you can see the cardboard "form" (a chunk of a shipping tube) that I glued in with some Mar-Glas. A couple layers of mat inside and out, and it'll be done. While waiting for the Mar-Glas to kick, I took the passenger door off, and fixed the upper hinge. The door had come open underway when the original builder had it, and ripped it right off the car. The rapid exit broke the upper hinge, which still had a big chunk missing from the top. I built it up with weld, jigged it up in the drill press and drilled a new hole. The door had the corner scuffed of too, so I swiped a little of the 'glass on it and will square the corner back up.
    The Chevy rear turns out to have a ratio of 3.75:1, which should make the 283 pretty happy, although I'd kinda like a
    700R4 instead of the 350 TH that came on the 283. That may be a good investment for me, so that may be s something to look for.
    16002811_10212414445258836_2475633456816441883_n.jpg 15977260_10212414444658821_2242590899223846970_n.jpg 16003170_10212414445578844_1405229561038925545_n.jpg
    kiwijeff, loudbang and oldsjoe like this.
  6. oldsjoe
    oldsjoe
    It's all the little things that suck up our time Brian keep pluggin! Joe
    loudbang and flynbrian48 like this.
  7. You're making good progress Brian - hand in there. I think that gear ratio was called a 3.70 by GM. I had a '62 Corvette for many years... it came with a 3.70 and left with one. It's amazing what we put up with in terms of cruising rpm's back in the old days.
    flynbrian48 likes this.
  8. flynbrian48
    flynbrian48
    I was sorta guesstimating that ratio, I indexed the drum and backing plate with a sharpie, and spun it once and counted how many times the pinion flange went around. I figured it'd be steeper geared that the Ford 8" from a Mustang I have under the bench, but figured the 283 would like the lower gear. It should be fun to drive, we'll just have to get used to thinking it should shift one more time.! :)
  9. oldsjoe
    oldsjoe
    kiwijeff and loudbang like this.
  10. flynbrian48
    flynbrian48
    16266162_10212519724730757_3603639506430287837_n.jpg 16142313_10212519724890761_1686832476450757326_n.jpg
    Got the package tray/top well/seat support for the '34 done today! Thanks to those who gave advice, I had no idea what was supposed to be there. I used glued up spruce from Menards, I'll pull it apart and paint everything. The top hinge mounts are dropped down 2", and the mounts I made for them are also the supports for the top well tray. I love it when things come together!
  11. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    FB,
    Great job all the way around!!!!!! Keep them pix coming. Perhaps you could post the feature of when that roadster was in the mag with the deuce as well???
  12. flynbrian48
    flynbrian48
    Cyclone Kevin, kiwijeff and oldsjoe like this.
  13. oldsjoe
    oldsjoe
    Lookin good Brian that's some work! Joe
  14. flynbrian48
    flynbrian48
    Thanks. The top edge of the body has a length of 1/2" conduit glassed in, that follows the curve of the body very well from door post to door post. There are two little tabs at the rear that the package tray, or the vertical part of it anyway, bolts to, you can see the two carriage bolts I used to bolt the wood panel to them. The sides have tabs about 8" long and 2" deep, light steel, that I welded the top mount tabs to. To these, I welded strips of light 1 1/2" angle iron, that the package shelf bottom bolts to. I'll make a tab at the front to bolt to the door jamb to stiffen that up a bit. It's very solid now. Tomorrow I'm going to fill and glass in all the holes in the dash to get ready for the new one.
    oldsjoe likes this.
  15. flynbrian48
    flynbrian48
    ImageUploadedByH.A.M.B.1485221754.962983.jpg ImageUploadedByH.A.M.B.1485221770.542921.jpg
    Dash ideas. Red one is my own Diamond T truck. I'd put the big speedo in the center and two small ones on each side. The other one is a real Auburn speedster, I'd have to get new gauges to mimic that.
    kiwijeff, 36 ROKIT and oldsjoe like this.
  16. flynbrian48
    flynbrian48
    ImageUploadedByH.A.M.B.1485298467.398563.jpg ImageUploadedByH.A.M.B.1485298479.997388.jpg
    Dash panel mocked up. I slipped with the cut-off wheel on the last gauge hole and mad a booger in the stainless panel. Dammit.
    Jeff34, brEad, loudbang and 3 others like this.
  17. oldsjoe
    oldsjoe
    I know that feeling Brian, why does it always seem to happen on the last hole? Maybe a little larger bezel piece will cover that slip up. Joe
    brEad and loudbang like this.
  18. flynbrian48
    flynbrian48
    There. I fixed it.
    Besty34, kiwijeff, Jeff34 and 4 others like this.
  19. flynbrian48
    flynbrian48
    And I put gauges in the firewall. Hopefully the tach will work.
    Besty34, MrPhat40, kiwijeff and 4 others like this.
  20. oldsjoe
    oldsjoe
    That's cool as hell Brian! Joe
  21. That is going over the top Brian , Gonna be a SWEEEET ride when you get done with it.
  22. Aaron D.
    Aaron D.
    I liked that option the best, looks great.
  23. flynbrian48
    flynbrian48
    Thanks guys. My wife thinks the two little panels to the side are too much, but hey, it's my car, right? ;-)
  24. flynbrian48
    flynbrian48
    Slung a little mud on the firewall today too.
  25. flynbrian48
    flynbrian48
    And the firewall gauges.
    kiwijeff, OahuEli and loudbang like this.
  26. oldsjoe
    oldsjoe
    Heck all I got accomplished today was dropping off some wheels to get sandblasted! What the heck Brian! Joe
  27. MIKE-3137
    MIKE-3137
    great build..It's cool with either dash..
  28. loudbang
    Wives don't do cars!! :eek: It looks pretty spiffy to me. :)
  29. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Here is mine which I know that your 34 had some form of inspiration for mine, I remember that article but forgot all about its color. IMG_9073.JPG IMG_9226.PNG My pix are just as blurry as I haven't really any in this I-Phone pix.
    Thanx for posting the 83 pic, I started this about the mid 80's for a former employer that had Hot Rod Shop in Arcadia. It was headed in a High Tech direction, but I had to own it and try to make it as traditional as possible without taking out its P&J's chassis components.
  30. flynbrian48
    flynbrian48
    I love your car, it looks like it's about the same shade of maroon-ish purple that this one was. I don't mind the color, but it reminds me too much of the the purple PT Cruiser we had (totally my wife's doing ;-)! This one will look pretty much like the top photo, minus the WW's. I'm getting anxious to start painting. As soon as the weather cooperates, it'll get color. There's about a days worth of body-work to do, and then several days of priming, sanding, painting polishing. I can hardly wait!
    oldsjoe and Cyclone Kevin like this.
