Hot Rods Fluid Coupling Hydramatic sealant
Discussion in 'The Hokey Ass Message Board' started by KCTA Chris, Nov 8, 2019.
  1. KCTA Chris
    KCTA Chris
    Any recommendation for the special goo to seal up my torus coupling around the crankshaft?
    I've heard everything from rubber cement to Gasgacinch to a guy who will sell me his magic bottle and bolts (I dont need) for an amazingly high price. I'd like to only do this job once.
    Thanks!
  2. raven
    raven
    Are you making progress on your coupe?
    r
  3. Did you open the torus and change the O rings? That is a cheap and important repair for an old slant pan.
  4. 56sedandelivery
    56sedandelivery
    There used to be a "special" sealant that was used with the old cast iron, single/dual range, single coupling, Hydra-Matics; and it's no longer available, anywhere. I think as long as whatever you use, does't harden completely, you should be fine. Use it on the crankshaft surfaces, and on the bolt threads; just don't go overboard, and clean off any excess. And, I'm sure you already know, these transmissions used a pilot bushing, similar to manual transmissions used.
    I am Butch/56sedandelivery.
    warbird1 and KCTA Chris like this.
  5. Doublepumper
    Doublepumper
    from WA-OR, USA
    I have Pliobond 30 in my notes that states it is a good sealant for this. I haven't used it, so can't confirm it's the best to use.
  6. KCTA Chris
    KCTA Chris
    Slow Progress... slow.
  7. KCTA Chris
    KCTA Chris
    Just got it back from the "expert" should be ready to bolt up!
  8. KCTA Chris
    KCTA Chris
    Pliobond! I believe I heard of that before. that sounds like It should work.
  9. raven
    raven
    Hey I might be in need of the ‘expert’ soon...
    r
  10. Yes Pliobond 30 is the stuff; don't know if it's still available. I used Aviation Permatex on the last two Hydro's I rebuilt.
  11. I have both Pliobond & Gasket Eliminator send me a PM
    Thanks, Dave
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ I see Pliobond is still available to purchase. But which one of their cements is best?
  13. KCTA Chris
    KCTA Chris
    Pliobond 30. fired up and not a drop spilled.
    Now I'm using that goo for all kinds of things.
    warbird1 likes this.
  14. Doublepumper
    Doublepumper
    from WA-OR, USA
