Flowmaster muffler overheating
Discussion in 'The Hokey Ass Message Board' started by johnod, Aug 5, 2012.
  1. johnod
    johnod
    Has anyone had a problem with this?
    Mine burned a hole thru the carpet, thru 2 layers of insulation.
    After lowering the mufflers , you can still not touch the floor as its still way hot.
  2. Flipper
    Flipper
    from Kentucky
    Yep, they do get hot.
  3. Deuces
    Deuces
    Sounds like your running your motor waay too lean.. Fatten up the jetting on your carb!! And redo the timing... I'm running a set of Flowdaddys on my '91 Fox car and never had that problem...
  4. GassersGarage
    GassersGarage
    I ran the 3 chambered Flowmasters with no problems.
  5. I've run them for years and havent even browned the paint on them.
    Too lean as stated above?
  6. Gman0046
    Gman0046
    They also sell muffler heat shields.
  7. Deuces
    Deuces
    That's what I have on mine and they're still freakin' loud... :eek:
    Must be that .542" lift cam I'm running.. :eek::rolleyes:
  8. shmoozo
    shmoozo
    from Media, PA
    Yeah, that sounds like a likely source of the problem. At the very least get a tuning expert to look at that jetting and timing, and don't be disdainful of the use of an exhaust gas analyzer to sort it all out.
  9. oldolds
    oldolds
    Some cars seem to do that. It may be lean jetting. It also may be the way the air flows under your car. Heat shields may be needed.
  10. Really, you guys determined the condition of his engine by this diagnosis?
    So tired of hearing "lean" conditions for every ailment.
    Seriously; hot mufflers are not uncommon. Flowmasters take the sound wave energy and reflect them against each other and that causes heat. Therefore, this type of muffler will always run hotter than "traditional" mufflers.
    If your floor insulation/carpet is burning because of this, the mufflers are far too close to the floor. Use a one hand rule. You should be able to able to get one hand between the exhaust and the floor at a bare minimum.
  11. johnod
    johnod
    Flat hand?
  12. gas pumper
    gas pumper
    I can't resist this anylonger:D.... The wrong weight oil in the muffler bearing can cause overheating. unless it's the multiple bearing design that uses silicon grease.
    buymeamerc likes this.
  13. johnod
    johnod
    Well duh, even i know this.
    Thats why I use the new sealed bearing design from Dewey and Scruem.:p
  14. 41woodie
    41woodie
    I run them on the woodie without problems. Of course they are wrapped with thermal wrap and there are two layers of foil/bubble insulation under the fiber pad and carpet. I would think that if the muffs are getting that hot you'd see problems under-hood also. Are you running headers? If you are running headers that are thermal wrapped it's possible that it's carrying the heat further into the exhaust system and the first "outlet'' for all of that heat is the mufflers.
  15. Ebbsspeed
    Ebbsspeed
    They also run hotter the closer they are to the motor. Not much, but it does make a difference.
    What kind of insulation are you using?
  16. Yeah, flat. should be able to reach all around the muffler or components. Without forcing of course.
  17. isky1843
    isky1843
    This!!! It could also be the lack of ZDDP in the oil used to lube the muffler bearing.
  18. Hyway Hauler
    Hyway Hauler
    Could be a timing issue...If your engine timing is retarded even a few degrees, your exhaust will run way hot. Check to see if your headers or manifolds are glowing at high RPM...
  19. squirrel
    Just wait a few months, you'll be glad for the heat.
    Seriously....yeah, mufflers get hot. Yeah, engine tune can affect how hot they get, as well as other variables.
    Pictures?
  20. drptop70ss
    drptop70ss
    from NY
    Flowmasters on the Buick are spray bombed black and they havent gotten hot enough to wrinkle the paint. Maybe you have a mouse nest in there :)
  21. 1964countrysedan
    1964countrysedan
    from Texas
    Check for a small leak at muffler joints. Let us know what you find.
  22. Carnuba
    Carnuba
    OK, I read every response and no-one suggested this. Flowmasters will run blistering hot and burn flooring even when properly spaced from the floor if they're installed BACKWARDS. They are directional, and it's very important they get installed correctly. I had a car that with no interior was smoking the POR 15 off the floor on one side only. THAT Flowmaster was installed backwards....and the prob gone after I switched it around
  23. The "1 hand" rule is what we used when I worked in muffler shops. If you can pass your hand between the pipe, muffler and whatever, you should be okay.
    Bob
  24. squirrel
    You're right...the big orange INLET sticker needs to go towards the front of the car. I forgot all about that.
  25. Engine man
    Engine man
    from Wisconsin
    I had my Borla mufflers getting very hot and I found that mice had put dog food in them.
  26. 1964countrysedan
    1964countrysedan
    from Texas
    To the original post...
    What was the solution?
  27. Gman0046
    Gman0046
    Gas pumper, in Kentucky we use KY Jelly.
  28. Use some Porters and forget about all the other problems
  29. Deuces
    Deuces
    Thank you sir!.. I'm glad you agree with me on that.. :)
  30. johnod
    johnod
    Well the solution has not been arrived at yet.
    But I think this is the solution I'm going to be using.
    http://www.spintechmufflers.com/700...000-round-cruiser-series-muffler/cat_120.html
    It will solve proximity problems.
    I need to get under the car and take some measurements.
    Mufflers are not in backwards, I think they're just too close to floor, and I have seen some stuff on the web about them running hot too.
    Also will be installing AFR gauge so that should help with getting mixture right as well , should that be part of the problem.
