not sure if this qualifies as a floater but since it isnt conected to anything that you can see it maybe close enough
Is that anything like those "potato slicers" that spin in your wheels while your sitting at a stoplight????...
here is a picture of what im mocking up, plan to do a floater, probably add some small lights at the end of the bar, and i have a 49 merc grill surround i cut out of a junker merc, so i plan to graft that around the floating set up. should be bitchen. <br> <br> http://www.mitchelltannahill.blogspot.com
Sure you have, its a custom thing. It means the grill appears to float in the opening. IE no mounting points are visible.
Thanks for posting, lets see some more. Im looking forward to seeing yours finished Mitchell. Nice Chevy imnuts. Looks right at home on your 53.
I love grills almost as much as hub caps. Here is my floater; two '54 Chrysler top grill bars with a '51 Ford grill suport mounted on the bottom. '50 chevy blinkers mounted inside a chrome bullet. Happy Trails, Mick
Here you go. Repop '53 Corvette grille with '53 Chevy turn signals mounted in reversed 2-cup measuring cups. (Yes, my running light housings are polished stainless steel measuring cups!)
my '51 plym. Built w/ the left over stainless from the stock opening and dummy spots for the bullets see the whole build here http://www.jalopyjournal.com/forum/showthread.php?t=581049&highlight=jcs64 jeff
