Flattie / T-5 Rear end Ratio?
Discussion in 'The Hokey Ass Message Board' started by 87Heaven, May 9, 2011.
  1. 87Heaven
    87Heaven
    I am at that point in my project where I have to decide what rear end ratio to use.
    It's a 1940 Ford Coupe about 2800 lbs, pretty well modified 276 ci 51 Merc
    a T-5 w/ .74 overdrive ( I forgot the 1st gear ratio) I think it 3.50.
    I have a set of 3.07 and a 3.73 gear set on hand.
    Which one should I use.
    I ran the calcs on both so technicaly I'm aware of Speed vrs RPM.
    But in reality I would like to hear from someone first hand who's running this set up.
    There is allways more to it than just running the numbers.
    Thanks in advance.
    Manuel
  2. Dirty Dug
    Dirty Dug
    I just got my '30 roadster on the road. It has a 255 flathead, t-5, and an eight inch. I'm running 3.40 gears with 7.50x16s. It turns 1900 rpms at 70 mph, with good pick up in first gear. You're probably not running that big a rear tire so I'd say the 3.73 would work out quite well for you. hope that helps.
  3. Deuces
    Deuces
    from Michigan
    First gear ratio in a Ford V-8 T-5 is 3.35 I think??
  4. flatheadpete
    flatheadpete
    from Burton, MI
    I had 4.10 gears in my banjo with a Merc and t5. Got over 30 mpg and ran like all hell.
  5. nailheadroadster
    nailheadroadster
    The rear tire diameter will make all the difference. Like Dirty Dug said, a 31" diameter tire (like his) versus a... I dunno, a 28" tire will change everything. Try the numbers using this :
    http://www.csgnetwork.com/multirpmcalc.html
  6. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Need to know the tire Dia. Without knowing how your Flattie performs you could
    go with 3.73
    Im putting 3.73 in my coupe with a flathead and 31" tires. Should really fly down the hwy! May even need to go to 3.90s
  7. Ole don
    Ole don
    With that much weight and barn door effect, run the 3.73
  8. 87Heaven
    87Heaven
    You guys are awsome.
    I feel better. I was leaning towards the 3.73 but I was affraid of having a stump puller where first gear was good for about 5 feet:)
    I havent decided on tire size, but it wont be too big. The car will be lowered some and I just want to fill the wheel well. What I have on there now is about 26" tall. The tire size can change as time goes on.
    Thank again guys!
