Technical Flathead won't start!
Discussion in 'Traditional Hot Rods' started by LukeCrawford, Dec 26, 2015.
  1. LukeCrawford
    LukeCrawford
    No but I'm looking haha.
  2. LukeCrawford
    LukeCrawford
    Put a 12 volt battery and some.new fuel in it and it fired right up.. I'm going to just convert it to 12volt. 6 volt is trouble hahaha
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    A lot of people install an 8 volt battery in them without having to deal with gauge and light adaptation.
    clem likes this.
  4. ROADSTER1927
    ROADSTER1927
    With the proper 6V battery and the big 6V cables there is no need for 12V. Gary
  5. trades707
    trades707
    from Oregon
    Did the car sit too long with alcohol gas? If the vapor has left the fuel, it won't start. try just a bit of fresh gas in the carb.
    Abe
  6. LukeCrawford
    LukeCrawford
    I agree but 12volts better, wanted to keep it 6 volt but oh well. Just happy it's running again
  7. Slopok
    Slopok
    So what was the initial problem???
  8. I believe he said bad fuel and a crappy battery.
    But he said he pulled the motor out.:confused:
  9. Slopok
    Slopok
    He must've had the EASY button o_O.
    belair likes this.
  10. Slick Willy
    Slick Willy
    Or a bad condensor...
  11. fridaynitedrags
    fridaynitedrags
    I remember cutting the leather tongue out of an old pair of shoes to put into the fuel pump actuation lever to make the pump actuation rod think it was a little longer. The rod rides on the cam and it wears down after a while. The result is little or no fuel coming out of the pump. Might want to check that.
  12. dan griffin
    dan griffin
    In the old days a 3/8 by 3/8 flathead would start on 6 volts they just din't turn over very fast. A small washer in the pushrod cup on the fuel pump will also take up some of ware.
  13. AULIZ
    AULIZ
    If all are correct (condenser, points, coil, battery, advance, fuel, sparkplugs,...) it fire up good 6volt.
    If not sure that all are good condition or right installed 12V is easy choise.
    I had in my ex. roadster 6V and worked OK and very good after bolted on Harman Collins magneto (recoiled). Little spark, little gas, little compression, What else 4stroke engine needs,... Now a days those 12V to 6V converters are easy to install (gauges) and cost is few dollars.
  14. Gary Addcox
    Gary Addcox
    My Dad was a flathead lover forever. As a small kid, I remember him always having to replace the coil on those things. Good luck.
