Hot Rods Flathead water pump and oil questions
Discussion in 'The Hokey Ass Message Board' started by hombres ruin, Jul 2, 2018.
  1. hombres ruin
    hombres ruin
    hi guys I have a stock 41 ford coupe with 20,000 miles on the Flathead stock water pumps which I don’t know how long they have been there. Recently found some oil under the radiator cap about the size of a quarter after I drive it. I have a new rad about 2 years old . I drained the rad and found no oil in the water. I also have some play in the pump head where the belt goes, also oil accumulation on the motor mounts and arm on the mount. All on the drives side. Nothing on the passenger side. No loss of water from rad, no water in the oil , no combustion gases in rad per test. No overheating at all, no smoke or water out the back.Now I was told that the seals on these pumps wear out and the lubrication of these bushings is from the engine oil. This wear could put oil in the rad. I want to get them rebuilt by skip haney. Had this happened to anyone else. ?
  2. alchemy
    alchemy
    I rebuilt my stock pumps over a decade ago. I used the stock-style pre-48 rebuild kits available from the parts houses and did it myself with a big vice and some sockets to press the parts on and off. When I leave the hood sides off I can see a slight sprinkle of some anti freeze on the fenders after a hard run. Nothing that really worries me though.
    I think if your pump is really worn, like you say it is letting oil run down the front of the pump, you probably need to rebuild it. If you are having overheating problems then maybe Skip's super rebuilds are the way to go. If they currently work well to keep you cool, maybe try it yourself.
  3. Bruce Lancaster
    Bruce Lancaster
    Stock lubrication through 1948 is by 2 secret passages from front of valley down into pumps!
    I think new repros use sealed pump bearings, as do Skip's...don't worry til things get messy, then either a stock rebuild or a modern cure with digital bearings or whatever is easy.
  4. hombres ruin
    hombres ruin
    Thanks Bruce.. in your experience does this happen often? I panicked and thought the worse when I saw the oil and thought what the hell is going on. I spoke to skip he said he uses bushings for his rebuild . Is it hard to get oil in the rad on a flathead if your water pumps are good?
  5. Bruce Lancaster
    Bruce Lancaster
    All manner of little leaks were common from both routine wear and disastrous engine failure! From what you reported yours sounds like minor wear.
    Ford Parts book drawing provided by Dr. Van Pelt
    Note the highly sophisticated devices (in engineering terms, "washers") used to keep water and oil apart.
    Also note that the heavy truck pump is a somewhat different beast.
    drawing here:http://www.vanpeltsales.com/FH_web/flathead_drawings_engines.htm
    Moriarity likes this.
  6. Bruce Lancaster
    Bruce Lancaster
    As with most fluids in early Fords, this stuff was expected by Henry to operate on the honor system. Fluids were told where they were to work, and the boss damn well expected them to do their jobs properly.
  7. Mac VP
    Mac VP
    The new pumps have three nice features:
    1) sealed ball bearings instead of bushings
    2) modern carbon-ceramic seals rather than fiber washers
    3) improved impeller design with curved vanes
    The curved vanes reduce cavitation of the coolant.....this is a churning action that tends to produce bubbles in the coolant at the impeller. Bubbles don’t pump as well as fluid so the curved vanes are a nice improvement. Last but not least.....the pumps are all new.....no old castings etc, and are ready to bolt on. They just plain work!
    If you’re doing a restoration, getting Skip to rebuild the original factory pumps would be the way to go, and he does nice work. If the new pumps will work for you, we sell them.
  8. Bruce Lancaster
    Bruce Lancaster
    And do note that Mac VP is one of the few early Ford dealers who actually knows his early Fords!
    Moriarity, alchemy and flatford39 like this.
  9. hombres ruin
    hombres ruin
    Thank you Bruce for your advice, much appreciated. I will get some new pumps and see what happens. Hope this fixes the oil in the rad situation.
