Technical Flathead V8 clutch linkage ratio
Discussion in 'Traditional Hot Rods' started by Truckedup, Jun 2, 2014.
  1. Truckedup
    Truckedup
    I'm ready to fabricate the clutch linkage On my wing tank car build. Engine is a mid mounted V-8 60. Linkage will be cable operated,there is absolutely no room for a hydraulic set up.The pedal and parts will be hand fabricated.
    I assume the clutch release shaft lever used on a V8-60 is similar to the larger Flatheads? I need to know the stock bell housing clutch lever length and the approximate leverage ratio of the stock floor pedals. Thanks
  2. 36tbird
    36tbird
    Measured on a '39 pedal assy, 1 3/8"
    From a '36 throwout bearing lever, 3 3/8"
    Measured with a tape measure while reaching in amongst some other parts by eyes that need a new Rx on glasses.
  3. Truckedup
    Truckedup
  4. DD COOPMAN
    DD COOPMAN
    Essentially a 2.5 to 1 ratio, given the above figures. DD
  5. Truckedup
    Truckedup
    I built a cable linkage from the measurements given here and the clutch feel is very good!
