i was told i can bolt some up and not cut anything. just change the oil pan and bolt on and go. where can i find them? thanks!
this is the one you want. i still need to find out the place that sells them. i'll get back to you asap.
www.rodncustom.com Part # 49/51 shoebox: 2501 49/51 mercury: 2503 52/53 ford & merc: 2505 ....Providing those were one of the cars you are talking about (just going by the fact that you mentioned needing to change the pan).
thanks man! i have the speedway catalog in front of me but can't find it. sorry vato, i got impatient and had to ask!
Depending on where the motor ends up, you may have oil filter clearance issues. I ended up using a remote oil filter on mine. Also, check your radiator to water pump pulley and fan? clearance.
they also have a kit where you can have the oil filter point forward. you bolt in the 90 degree adapter. also we used undersized pullies to get some more pwr from the motor.
ok, so what else do i need. i'd like to buy everything so i can bolt and go. i know it won't be that easy but just have the things i need. hey dante do you really want the roof?? thanks again!
I concur on the remote oil filter, Summit had the cheapest one. Also the drivers side exhaust manifold needs to drop out rear of the last cylinder, angles back to clear the steering box.
