Hot Rods Flathead Starter Woes
Discussion in 'The Hokey Ass Message Board' started by Sheep Dip, May 5, 2017.
  1. Sheep Dip
    Sheep Dip
    from Central Ca
    Looking for an answer from all of you Flathead V8 parts Guru's.
    A while back I was trying to replace my starter in my Flathead this is what came out, the old style Henry Ford impact spring on the end
    upload_2017-5-5_16-16-22.jpeg This is what they sent me as a replacement
    upload_2017-5-5_16-18-46.jpeg I could no way shape or form get the end of this starter past my flywheel/ring gear? My only thought, was I have a Truck bell housing which is cast and a little thicker vs a steel which is thinner.
    I ended up with this and am happy but I'm at a loss as to why the replacement would not fit other than the bell housing thickness.
    Any info just for general knowledge is welcome. upload_2017-5-5_16-16-22.jpeg upload_2017-5-5_16-18-46.jpeg upload_2017-5-5_16-24-6.jpeg
    Handfull54 likes this.
  2. Dirty Dug
    Dirty Dug
    I had the same problem with a stamped steel truck bell housing. The "new and improved" version would not fit.
  3. Bandit Billy
    Bandit Billy
    I am using this on my 8BA
    I changed the flywheel to an aluminum one, this starter engages perfect. It bounced a bit across the top of the ring gear at first. I had to removed the starter adapter plate, elongate the mounting holes, dowel it and the bell housing so it wouldn't move back and for ease of install. Other than that, it works great on my blower motor.
  4. Sheep Dip
    Sheep Dip
    from Central Ca
    The high torque starter fixed it for me too. I'm real curious as to why this so called replacement flat ass won't work and alls they need to do is slightly reduce the diameter of the impact snubber.
  5. lodaddyo
    lodaddyo
    popawolf likes this.
  6. Bandit Billy
    Bandit Billy
    I have an original starter you can have free for shipping expense.
  7. The tractor style bendix will fit with a bit of wiggling around, its a superior design, I ran into the same problem but it eventually popped in. They work well, havent broken it yet and its been several years since the swap.
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes they DO fit. I too thought they wouldn't. It does need to be angled just right to slide past the flywheel.
    It will go in.
    I installed two in and they work perfectly.
  9. alchemy
    alchemy
    What year pans are you guys having trouble fitting them into? I've seen them in the catalogs, but haven't bought one yet.
    keith27T likes this.
  10. Sheep Dip
    Sheep Dip
    from Central Ca
    Mine was 48 truck motor/pan and bell housing. I tried every angle possible, even grease to see the contact points on the inside of the housing. Gave up and bought a high torqe mini.
  11. alchemy
    alchemy
    A 48 truck used a late model style engine, so that is different than the pre 48 stuff I use. I would think the pre 48 pan would be even worse than a late model.
    Petejoe likes this.
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    I installed two into a 40 pan.
    Went in after a little finagling and some cussing.
  13. Gene Boul
    Gene Boul
    Great send it to me.I can send you 20.00 or so for shipping? Gene @ 832-514-5668
  14. Gene Boul
    Gene Boul
    Flathead starters can be a real problem. I ended up with three starters that were too long. I believe they are for an automatic! The only way to use one would be to cut out the back of the starter pocket!
  15. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes Gene, I ordered an automatic starter by mistake one time. Frustrating.
  16. Bandit Billy
    Bandit Billy
    So this brings up a good question. When I was having trouble aligning my mini high torque starter I had to knock the pocket out of my 8BA bell housing leaving an unsightly hole. I destroyed it taking it off, now what do I do?
