Technical flathead pistons and valves
Discussion in 'Traditional Hot Rods' started by Cutlassboy68, Dec 13, 2011.
  1. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    So i have this box full of std. pistons and valves. Is there any use to these? if not im making some art figures with them. Let me know cause i dont wanna destroy something usable to someone...
  2. flatjack
    flatjack
    Are the pistons 3 1/16 or 3 3/6? If they are 3 1/16, not worth much unless someone is sleeving an engine. Also, 49 - 53 exhaust valves are worth keeping.
  3. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    Im not sure what year these are for, i have 2 sets... how can i tell?
  4. I save any part that can be reused maybe someone out there wants one and I can help him out.................
    measure them
  5. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    I mean the valves, what dimensions are ok?
  6. farmboat
    farmboat
    from Lucas, KY
    I may need a couple standard model a pistons.
  7. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    Farm if you can use these ill give you a set
  8. Retro Jim
    Retro Jim
    I would never throw away any stock parts from old engines as long as they are still good to reuse . I understand that most end up re-boring to a bigger size but since you can only rebore so much you then have to sleeve the cylinders thus you will once again need those stock size pistons .
    You could just make a post and try and sell them . I bet someone will need them ! You could even use those on-line auctions as well .
    Just a thought !
    Retro Jim
