stock 8ba style gen mount, SOLD stock mismatched set of 8BA heads, they appear to be the same in the inside just he marking on the outside are a touch different SOLD RED EAB ford stock 24 stud flathead, these should clean up nicely. they might need some machine work on the deck surface. they also have the stock oil filter attached. it is in ok shape but missing the top bolt. From what I have read these are heads to have as they have a higher compression then the stock 8BA heads and better then the stock mercury heads SOLD ford manual steel bellhousing, in good shape just has some stuck on old grease/dirt. measures 6inches from the widest part to the smallest. SOLD
